Old 09-21-2009, 09:32 PM
mjabon mjabon is offline
getting data out of an exe
Hello. I want to publish a script as an exe and it writes to a file. I want to have axcess to the data in that file after the exe is closed (ie I want it saved in the same folder the exe is stored).
How can I do this? Right now nothing comes out of the exe.
Old 09-22-2009, 10:58 AM
The documentation for Publishing as an EXE describes how to accomplish this. Specifically, you need to use the viz.res.getPublishedPath() command.
Old 09-22-2009, 11:49 AM
Right, but that just returns a string - the path of the file. It doesn't output the file.
Old 09-22-2009, 11:53 AM
Of course it doesn't, it's up to you to create the file using the new path and write to it:
f = open( viz.res.getPublishedPath('output.txt') , 'w' )
f.write('bla bla bla')
f.close()
Using 5DT plug-in with the data coming through network... mcicek Vizard 1 05-18-2009 05:17 PM
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
data glove navigation arielasso Vizard 6 10-24-2007 02:15 PM
