Old 07-31-2009, 08:59 AM
Enlil Enlil is offline
Displaying multiple gui items in one line
I am trying to create a set of sliders with a check box to indicate if the slider is being used. So, I want a check box followed by a slider on the same line. The intention is to have a list of these, and use the check box to indicate if the slider is in use. Is this feasible, and if so, how do I do it?
Christian
Old 08-03-2009, 04:56 PM
Here is a simple script that shows how to create a groups of sliders with checkboxes. Hope this helps:
def addSliderCheckbox():
	"""Create group node containing slider and checkbox"""
	group = viz.addGroup(parent=viz.SCREEN)
	group.slider = viz.addSlider(parent=group)
	group.checkbox = viz.addCheckbox(parent=group,pos=(0.15,0,0))
	return group
g1 = addSliderCheckbox()
g1.setPosition(0.2,0.5,0)
g1.checkbox.set(True)
g2 = addSliderCheckbox()
g2.setPosition(0.2,0.4,0)
g2.slider.set(0.5)
Old 08-04-2009, 07:17 AM
Thanks, that is pretty close to perfect! I don't suppose there is a good way to organize these into a box, like vizinfo allows you to do with some elements?
Christian
Old 08-04-2009, 04:06 PM
You can use the undocumented vizdlg module to add the items within a panel. Here is a modified version of the script that uses the module:
import vizdlg
panel = vizdlg.Panel(layout=vizdlg.LAYOUT_VERT_LEFT,fontSize=25)
panel.setPosition(10,500,0)
	"""Create new row in panel containing slider and checkbox"""
	row = vizdlg.Panel(layout=vizdlg.LAYOUT_HORZ_CENTER,background=False,border=False)
	slider = row.addItem(viz.addSlider())
	checkbox = row.addItem(viz.addCheckbox())
	panel.addItem(row)
	return slider,checkbox
slider1,check1 = addSliderCheckbox()
check1.set(True)
slider2,check2 = addSliderCheckbox()
slider2.set(0.5)
Old 08-05-2009, 07:43 AM
Thanks, that is great!
Christian
Create line and vertex Chrissy2009 Vizard 2 07-20-2009 10:53 AM
Draw Line between Points Chrissy2009 Vizard 2 05-13-2009 04:42 AM
displaying random scenes etc cl113 Vizard 1 05-10-2009 05:14 PM
multiple views durf Vizard 3 05-07-2009 11:26 AM
Draw Line between Points selected by mouse Johannes Vizard 7 01-07-2005 02:50 PM
