I've been having the same problem that Kettle has for Max 2010. I'm running Windows Vista and it doesn't matter the complexity of the model, Max will not export.
Max export issue
Let's try another approach, it's very possible that I didn't update to the new version properly. I've uninstalled the plugin but still I'm not having any luck when re-installing. Are there residual files that might be left behind that could sabotage a new install?
Many thanks in advance, Kevin |
Are you getting a crash or just the error dialog you posted? The only thing you need to do is make sure 3dsmax is shutdown before running the installer.
Thanks for your reply farshizzo. I did have Max shut down before running the installer. I get that error the first two times I try to save an OSG file and then Max crashes.
The reason I asked if there is something I'm missing is because the error persists even after uninstalling and reinstalling the plugin. I know some kind of file is saved in the system because all export settings from the previous install return when I reinstall the plugin. This is even after the old OSGExp folder is deleted. ![]() I deselected everything but geometry and it still won't export. I've tried it with the default settings and that doesn't work either. |
Problem solved
Uninstalling Delta 3D v2.3 stops the errors. I think it's the Max exporter files within Delta that cause the conflict. Since uninstalling, no problems |
Hi tetralynx,
Thanks for sharing. |
| Thread Tools | |
| Big problem with OpenSG exporter for max to Vizard | omadawn | Vizard | 5 | 06-09-2009 11:51 AM |
| cal3d exporter | lqakane | Vizard | 0 | 03-02-2009 07:38 AM |
| cal3d exporter for 3ds max 2008? | masaki | Plug-in development | 3 | 09-25-2008 10:48 AM |
| cal3d exporter problem | visnova | Vizard | 1 | 06-15-2007 03:02 PM |
| At my Whits end with Cal 3D Exporter | shivanangel | Vizard | 6 | 02-25-2007 03:00 PM |
