Old 06-08-2009, 04:03 AM
katewilmut katewilmut is offline
Writing data to multiple files
I am only a starter with Vizard so this is probably a basic question.
I am using a flock of birds to collect position and orientation data. I have set up a program so it collects data for a set amount of time every time I press a key. I want to write each of these 'pieces' of data to a different excel file (trial 1 in 1.xls, trial 2 in 2.xls etc). In Matlab I would use a for loop to do this, which is want I have tried, but I can't get it to work in Vizard.
The loop doesn't seem to iterate each time, and I can't see a way to tell it to.
Many thanks
Kate
Old 06-08-2009, 03:00 PM
There is a link to python documentation in Vizard under the help tab. There are some examples of using a for loop in there. If you are still having trouble try posting an example of what's not working.
Old 06-09-2009, 01:54 AM
Jeff,
I have tried using the help and could get any further - below is the code I am using. At I said before the loop at the bottom just gets stuck and does iterate onwards for each button press.
Any help is greatly appreciated
Kate
import math
import viztask
import random
import vizjoy
subject = viz.input('What is the participant number?')
viz.move(0,0,0)
viz.eyeheight(0)
Trial = 0
myTracker = viz.add('flockofbirds.dls')
myTracker.reset()
viz.tracker()
ball=viz.add('soccerball.ive')
ballinitial = [0,0,8]
ball.setPosition(ballinitial)
def onKeyDown (key):
viz.callback( viz.TIMER_EVENT, mytimer )
viz.starttimer(0, 1/100, 5)
def mytimer(num):
print Trial
data = myTracker.get()
print data
a = data[0]
b = data[1]
c = data[2]
d = data[3]
e = data[4]
f = data[5]
tracking_data = open('tracking_'+ str(subject) + '_' + str(Trial) + '.xls', 'a')
tracking_data.write(str(a) + ' ' + str(b) + ' ' + str(c) + ' ' + str(d) + ' ' + str(e) + ' ' + str(f) + '\n')
for i in range (0,9):
global Trial
Trial = i
viz.callback(viz.KEYDOWN_EVENT, onKeyDown)
Old 06-09-2009, 05:44 AM
Jeff,
Kate
import math
import viztask
import random
import vizjoy
viz.move(0,0,0)
viz.eyeheight(0)
Trial = 0
myTracker.reset()
viz.tracker()
def mytimer(num):
	print Trial
	print data
	a = data[0]
	b = data[1]
	c = data[2]
	d = data[3]
	e = data[4]
	f = data[5]
	global Trial
	Trial = i
Old 06-10-2009, 01:31 PM
You loop should work, but there is no connection between it and your callbacks. It loops through and then leaves Trial set to a value of 8. If you want Trial to update each time a key is pressed then increment it in your keyboard callback function.
Trial = 0
def onKeyDown(key):
	global Trial
	Trial += 1
Old 06-11-2009, 02:03 AM
Thank you so much, I knew it was something silly I was missing but I just couldn't work it out. Much appreciated
Kate
Writing data more than once TrashcanPatrol Vizard 2 01-06-2009 04:56 PM
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
Writing text files with executable adimov Vizard 1 03-21-2008 04:21 PM
Data Files betancourtb82 Vizard 6 05-04-2006 03:43 PM
