Old 05-29-2009, 12:50 PM
Moh200jo Moh200jo is offline
Motionbuilder over VRPN
Hi
can I send real-time data from Motionbuilder over VRPN to vizard?
any suggestions would be appreciated
Old 05-29-2009, 01:09 PM
I don't believe this is possible without writing your own MotionBuilder plugin to stream the data.
Old 05-29-2009, 01:31 PM
could you please advice me what concepts are being used to write my own code to plug in into vizard?
Old 05-29-2009, 02:37 PM
This has nothing to do with Vizard. You need to write a MotionBuilder plugin that streams data over VRPN. Once you have this working, then any VRPN capable application will work with MotionBuilder, including Vizard.
We don't provide support for creating MotionBuilder plugins, you will need to contact Autodesk about this.
Old 06-01-2009, 02:58 AM
Hi Farshizzo,
Thanks for your replies
The data I’ll send over VRPN must be had a specific format (FBX or other) to be capable to control vizard’s avatar? can I write my a MotionBuilder plugin through Python and connect it with vizard's avatar ?
Before to starting write my code, could you please advice me whether there are any important points I have to be aware about them?
VRPN info sdiverdi Precision Position Tracker (PPT) 5 01-16-2011 12:00 PM
Sensable Omni + VRPN djdesmangles Vizard 2 05-26-2009 04:30 PM
VRPN or trackd with OptiTrack RigidBody vizmaster Vizard 1 08-13-2008 12:11 PM
swapPos and swapQuat with VRPN michaelrepucci Vizard 1 07-29-2008 11:27 AM
VRPN won't update Wytze Precision Position Tracker (PPT) 7 05-28-2008 07:15 AM
