Old 05-15-2009, 11:16 AM
nasr nasr is offline
hello paul...i tried rotating the object using the keyboard..by assigning keys for each axis....but i want to do this using mouse in order to reduce the number of lines of code...could u please tell me the function for that. how it could be done? i wil be waiting for ur reply..thankyou...
Old 05-15-2009, 11:37 AM
How about rotating an object when you hold down the right mouse button. You could use Jerry's code from this post to rotate the object after it is selected: http://forum.worldviz.com/showthread.php?t=2022
Any ideas on linking chess 3ds file with source code? djones1010 Vizard 1 04-24-2009 09:56 PM
Trying to integrate Source Code with Vizard djones1010 Vizard 1 03-10-2009 02:58 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 04:30 PM
3D Music Interface Psirus Vizard 3 02-26-2008 11:48 AM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 10:52 AM
