Old 05-05-2009, 04:37 AM
Chrissy2009 Chrissy2009 is offline
Stop moving after few seconds??
Hello all,
I'm trying to develop a application but now, I've got a problem:
I shoot a ball against other balls and then these balls collide. Like a billiard game. These balls are not on a table, they fly across the air. Therefore I set the gravity to [0,0,0].
This works very fine. But now the problem is that the balls are flying too long. It takes about 10 seconds till the balls stop moving. But I don't want to wait such a long time. The balls should stop moving after 3 seconds. Is this possible?
I searched the whole Vizard Documentation, but I can't find the relevant command.
I would be very pleased about every information and help.
Thanks a lot!
Chrissy
PS: Sorry for english mistakes
Old 05-05-2009, 11:24 AM
Moh200jo Moh200jo is offline
the sound like you have to use timer. Could you please looking at vizard functions because vizard has a timer function.
hope this helped you!
Old 05-06-2009, 02:09 PM
But I only initiate the shoot. Afterwards the balls move automatically.
Where do I have to set the timer?
My code to initiate the shoot is:
vec.setLength(vizmat.Interpolate(1,400,power.get()))
info.object.applyForce( vec, 1 )
One ball pushes the other balls away. And the time, until all balls will slow down, I want to constrict to max. 5 seconds.
Old 05-06-2009, 03:52 PM
to shoot balls each time, try to define a shooting function, may be something like this
HTML Code:
def shoot():
    pass
vizact.ontimer(5,shoot)#each 5 sec
this script could have what you are looking for
let me know if this helped you.
Old 05-06-2009, 11:34 PM
no - I don't think that's my problem.
Look. I've got one white ball and 14 other balls. Then I shoot the white ball against the other balls.
The white ball collides with the other balls and afterthat the other balls will fly across my room. I only initiate the shoot once!!
And now it takes about 20 seconds, until all balls will stop moving. And thats my problem.
Is there a command, like "stop moving all objects" or something like that?
Old 05-07-2009, 11:12 AM
You could loop through all your objects and set their velocities and angular velocities to zero.
for i in range (len(objects)):
	objects[i].setVelocity([0,0,0])
	objects[i].setAngularVelocity([0,0,0])
Start a timer when when the force is applied that will expire after 3 seconds then call your function that stops the movement.
Old 05-08-2009, 03:11 AM
Hi Jeff,
thanks for your answer. This is exactly my problem. Great!
Is it possible to slow down the balls, so that they don't stop fitfully?
Thanks a lot.
Old 05-10-2009, 01:16 PM
Is there no idea to slow down the balls steadily?
Old 05-10-2009, 02:47 PM
You could apply a small force opposite the direction the ball is moving. Here a function is called ten times, the first nine times getting the velocity of the ball and applying a small force opposite to it. On the tenth time the ball is stopped completely.
viz.phys.enable()
ground.collidePlane()
ball = viz.add('ball.wrl', pos = [0,1,8])
ball.collideSphere()
ball.applyForce([2,0,10], .1)
num = 1
def slowBall():
	global num
	#slow down the ball
	if num <10:
		vx,vy,vz = ball.getVelocity()
		ball.applyForce([-vx,-vy,-vz], .01)
		num+=1
	#stop the ball
		ball.setVelocity([0,0,0])
		ball.setAngularVelocity([0,0,0])
#call function 10 times
vizact.ontimer2(.3,9, slowBall)
How to stop vizact.move Jerry Vizard 3 06-04-2009 04:25 PM
moving and object by mouse but don't know how to stop the movement nlfrnassimi Vizard 8 04-26-2009 07:23 AM
how can I stop an action? nlfrnassimi Vizard 4 02-13-2009 12:59 AM
moving viewpoint vs. translating Head_pos bailenson Vizard 5 02-01-2005 01:51 PM
