Old 04-24-2009, 09:56 PM
djones1010 djones1010 is offline
Need help creating chessboard
The attached file should be placed into VizardChess folder inorder to compile correctly. You can download the VizardChess folder from the link above. It creates one row of white and brown squares then stops. I help completing the rest of the board.
	def Draw(self,board,highlightSquares=[]):
		boardSize = len(board) #board should be square.  boardSize should be always 8 for chess, but I dislike "magic numbers" :)
		current_square = 0
		for r in range(boardSize):
			for c in range(boardSize):
				(screenX,screenY) = self.ConvertToScreenCoords((r,c))
				if current_square:
					pic = viz.addTexture('brown_square.png')
					brown_square = viz.addTexQuad()
					brown_square.texture(pic)
					brown_square.scale(1,1,1)
					brown_square.translate(r-5, 0, 15)
					#self.screen.blit(brown_square,(screenX,screenY))
					current_square = (current_square+1)%2
					pic2 = viz.addTexture('white_square.png')
					white_square = viz.addTexQuad()
					white_square.texture(pic2)
					white_square.scale(1,1,1)
					#white_square.translate(r, 0,15)
					white_square.translate(r-5, 0, 15)
					#self.screen.blit(white_square,(screenX,screenY))
Trying to integrate Source Code with Vizard djones1010 Vizard 1 03-10-2009 02:58 PM
how to use ***.remove() & how to show words directly? (change attach source code) znchb Vizard 2 10-30-2008 12:33 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
