Old 04-21-2009, 03:48 AM
5ky1ine 5ky1ine is offline
linking view to avatar
is ther any way of linking the view to an avatar and walk around the environment using the keyboard like in a game?
any help will be really appreciated..
Old 04-21-2009, 06:41 AM
Moh200jo Moh200jo is offline
try the following code to link the avatar with the mainview
HTML Code:
mainview=viz.clearcolor(viz.SKYBLUE)
avatar = viz.add('vcc_female.cfg')
avatar.setPosition(0,0,9)
view = viz.MainView
link = viz.link(avatar, view)
link.preTrans([0,-0.5,-5])
Old 04-21-2009, 07:11 AM
I correct this what you are looking for.
HTML Code:
import vizcam
viz.add('tut_ground.wrl')
avatar.state(2)
handcontrol = vizcam.KeyboardCamera(forward=viz.KEY_UP,backward=viz.KEY_DOWN,turnRight=viz.KEY_RIGHT,turnLeft=viz.KEY_LEFT)
viz.cam.setHandler(handcontrol)
view = viz.MainView
link = viz.link(view, avatar)
link.preTrans([0,-1.5,5])
pos = avatar.getPosition()
Old 04-21-2009, 08:04 AM
thanks for the reply,
the code works fine apart from the avatar is in the walking state even when you are not pressing anything. is there anyway to make the avatar stand still when no key is being pressed?
Old 04-21-2009, 09:08 AM
yes just define a function to check the avatar state
Old 04-21-2009, 09:17 AM
can you tell me how that is done please
thanks
Old 04-21-2009, 09:39 AM
I correct something like this:
HTML Code:
avatar_position = avatar.getPosition()
def avatarstate():
	global avatar_position
	if avatar_position == avatar.getPosition():
		avatar.state(1)
		avatar_position= avatar.getPosition()
		avatar.state(2)
vizact.ontimer(.05, avatarstate)
I hope this will be helpful
Old 04-21-2009, 11:03 AM
Thanks that worked, but only one thing left, the avatar dosent have collision, it walks through the walls and other objects. any suggestions
View nlfrnassimi Vizard 4 03-12-2009 05:25 AM
Linking problems with Live Character Frank Verberne Vizard 5 06-04-2008 11:42 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 05:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 08:48 AM
Linking avatar 'bones' to a position tracker. zachhendershot Vizard 3 11-19-2003 09:26 PM
