Old 04-18-2009, 10:11 AM
durf durf is offline
disable ppt sensor
Is there a way to track 4 sensors and have the computer disable which ever sensor you designate and then have then activate it later on.
IE - you have ppt1 and ppt2 as sensonrs. I want to ignore ppt1 but still have it being tracked. Then later I tell it to not ignore ppt1.
I can clarify more if need be.
Thanks.
Old 04-20-2009, 10:24 AM
If you are using a link with the sensor you could disable and enable the link
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 12:24 AM
Calculating Speed with sensor durf Vizard 1 03-13-2009 10:25 AM
wiimote and sensor bar masaki Vizard 1 03-06-2008 03:07 PM
Multiple Copies of same sensor plugin RedSpikeyThing Plug-in development 2 02-12-2008 02:10 PM
using sensor data in Physics1.py Eunice Vizard 4 01-03-2006 05:18 AM
