Because you have repeats set to 1 this timer will be called twice and the path will be played twice.
vizact.ontimer2(wait, 1, path[object[x]].play) |
Oh!!! I always thought the second argument of vizact.ontimer2 was the number of times to active the timer. Sorry about that. I should set it to 0. I'll correct it and see what happened....
Thanks a lot! |
Thank you, Jeff. It works!
Now I make a little change on the reset part. I would like to reset the object (duck or ball) right before being played. But I got the following error: Traceback (most recent call last): File "C:\Program Files\WorldViz\Vizard30/python\vizact.py", line 2980, in __ontimer val = event.call() File "C:\Program Files\WorldViz\Vizard30/python\vizact.py", line 2803, in _callStatic return self.func(*self.args,**self.kwargs) TypeError: 'NoneType' object is not callable Could you please help me find the problem again? Thanks! Code:
import math
viz.clearcolor(0.5,0.5,1)
viz.add('tut_ground.wrl')
#Add 2 models.
#One is a ball, the other is a duck.
model = []
ball = viz.add('ball.wrl')
duck = viz.add('duck.cfg')
model.append(ball)
model.append(duck)
#Add the path.
#path[0] is for the ball, path[1] is for the duck.
path = []
for x in range(2):
pa = viz.addAnimationPath()
path.append(pa)
positions = [ [5,1,6], [0,1,3], [-150,1,6] ]
for x in range(len(positions)):
cp = viz.addControlPoint()
cp.setPosition(positions[x])
path[0].add(cp,x+1)
path[1].add(cp,x+1)
for x in range(2):
path[x].constantspeed(viz.ON,10)
path[x].loop(viz.OFF)
path[x].translatemode(viz.BEZIER)
path[x].setAutoRotate(viz.ON)
#Link the model to a path.
ball.link(path[0])
duck.link(path[1])
def mytimer(num):
pass
def reset(k):
path[k].pause()
path[k].reset()
model[k].setPosition(0,0,0)
#The following arrays means:
#Firstly: duck start to move
#After 3 seconds, ball start to move
#After another 3 seconds, ball start to move again
time_to_go = [0, 3, 6]
object = [1, 0, 0] #1 means duck, 0 means ball
#Create an array of timer action
for x in range(len(object)):
if (x == 0) :
path[object[0]].play()
wait = time_to_go[x] - time_to_go[0]
vizact.ontimer2(wait, 0, reset(object[x]))
vizact.ontimer2(wait+0.00001, 0, path[object[x]].play)
viz.starttimer(0,0,viz.PERPETUAL)
The error is in this line
vizact.ontimer2(wait, 0, reset(object[x])) Code:
vizact.ontimer2(wait, 0, reset, object[x]) |
Thank you so much for your help, especially at weekend.
| Thread Tools | |
| Display Modes | Rate This Thread |
| array problem | mrvr | Vizard | 8 | 03-10-2014 10:20 PM |
| Sound Looping Problem | JMOwens | Vizard | 4 | 09-29-2010 10:42 PM |
| Timer speed | Jerry | Vizard | 1 | 12-08-2006 12:01 PM |
| problem with female animations | vmonkey | Vizard | 1 | 10-07-2005 11:36 AM |
| Weird lagging/choppiness when avatars perform actions | vjonshih | Vizard | 8 | 11-30-2004 05:08 PM |
