Old 04-09-2009, 08:51 AM
Penguin Penguin is offline
wxImage to Texture
I'm using wxPython to get a screenshot from a hidden window how it is described here.
Now I want to use the screenshot image as a texture on a Vizard object (e.g. a plane) without writing it to the harddisk and read it again with viz.addTexture() because this would be slow for repetitive image generation with short time intervals.
Is there a way to load the wxImage direct to a texture? Maybe using viz.addTextureFromBuffer() in some kind?
Old 04-09-2009, 03:53 PM
Yes, you can copy the image data directly into an existing Vizard texture using the texture.setImageData() command. Here is a sample script:
import wx
def WXIMAGE_TO_TEXTURE(image,texture):
	"""Convert wxImage object to Vizard texture"""
	img = image.Mirror(False)
	tex.setImageData(img.GetData(),[img.GetWidth(),img.GetHeight()])
#Create wxImage from a bitmap
app = wx.PySimpleApp()
img = wx.Image('image.bmp')
#Create blank Vizard texture
tex = viz.addBlankTexture([1,1])
#Copy image to texture
WXIMAGE_TO_TEXTURE(img,tex)
#Create quad to display texture
quad = viz.addTexQuad(pos=(0,1.8,2),texture=tex)
Translating a texture and its Alpha shivanangel Vizard 5 12-02-2008 04:52 PM
3D Texture Mapping in Vizard? stefs Vizard 2 03-25-2008 03:34 AM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 12:12 PM
How to simply texture an avatar's head with a jpeg graphic? vr_boyko Vizard 3 10-26-2004 10:44 AM
