Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 04-07-2009, 12:57 PM
After checking out SketchUp, I don't think it can export animations to 3D formats like VRML. Plus, it's $500 for the Pro version which you need to export to common 3D file formats.
Anyone know if Blender can export OSG animations? It seems Blender can export to Cal3D well enough for Vizard to use it. That could be an animation workflow for Blender to Vizard. Vizard supports VRML animations, so if Blender can export animated VRMLs that could work as well.
Old 04-08-2009, 01:23 PM
just alex just alex is offline
Would it be possible to swap between a bezier path and a linear path? I could at least get some of the straight areas to go well then.
Old 04-09-2009, 02:06 PM
As long as you know how long one path takes to complete you could link your object to the second path when the timer, set to the time of the first path, expires.
Old 04-22-2009, 01:07 PM
blender OSG animation workflow
I figured out how to use Blender to create animation paths. This seems much easier than tweaking control points forever in Vizard.
Steps:
1. Install Blender.
2. Install osg export plugin. Download plugin. Copy the osgexport-2.42.py file into <Program Files>\Blender Foundation\Blender\.blender\scripts directory.
3. Learn how to animate a box in blender. This video provides a simple introduction: http://www.youtube.com/watch?v=FAZFfLmbD2k
4. Checkout the attached Vizard script that moves a car around with an animated box made in blender. The zip includes the .blend file.
path = viz.add('output.osg')
vizact.onkeydown(' ', path.hint, viz.RESET_ANIMATION_HINT)
path.disable(viz.RENDERING)
car = viz.add('mini.osgx')
linky = viz.link(path.getChild('Cube_geode'), car, srcFlag=viz.LINK_ABSOLUTE)
linky.preEuler([0, -90, 0]) #rotate car upright
viz.MainView.setPosition([0,1,-5])
light = viz.add(viz.LIGHT)
light.position(.5,1,-.5,0)
light.intensity(3)
viz.clearcolor(viz.SKYBLUE)
viz.add('tut_ground.wrl')
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 04:23 PM
speed on animation path whj Vizard 8 11-17-2008 07:41 PM
Cubic Bezier Curve whj Vizard 0 11-10-2008 01:52 PM
another bezier animation problem masaki Vizard 1 01-24-2008 02:29 PM
Smooth transition from Linear to Bezier in animation masaki Vizard 2 01-13-2008 11:22 AM
