Old 03-31-2009, 12:26 PM
Moh200jo Moh200jo is offline
battlefield example
I want to use battlefield example from 3Ds Max tutorial with vizard after exported it to WRL. I am trying to allow avatar walking on this scenes, the avatar should follow the shape of the ground. In addition, I would like to texture cloud image with the sky.
Any suggestion would be really appreciated.
I have attached the example.
Old 03-31-2009, 12:31 PM
attachment1
Old 03-31-2009, 12:38 PM
battlefield.zip:
Upload of file failed.
Old 03-31-2009, 06:47 PM
Try using the OSG exporter and exporting to the compiled OSG format, .ive. You could export the ground as one model and the rest of the scene as another model. Then to have the avatar follow the terrain when you use vizact.walkTo for the y value use your ground model. Check out this thread to see how to do that
http://forum.worldviz.com/showthread.php?t=1587
Old 04-01-2009, 03:20 AM
openthreadsWin32.dll
I cannot install it
it needs this
openthreadsWin32.dll was not found.
any help to fix this?
thanks,
Old 04-01-2009, 03:26 AM
I have attached battlefield.wrl with this thread
Old 04-02-2009, 06:12 PM
Which version of Max are you using? Did you download the OSG exporter for Max from our site?
Old 04-03-2009, 06:07 AM
Thanks Jeff,
I am using Max 2009. Yes I have downloaded the OSG exporter for Max from your site.
May I ask here... why it is difficult to work with my own .wrl while .wrl has been used by many examples from Vizard?
Regards
Old 04-06-2009, 10:43 AM
I have done it. OSG Exporter 0.9.5 shall be used for Max 2009
I could not have a control into main view that I have imported it.
please see my code.
HTML Code:
mainview=viz.clearcolor(viz.SKYBLUE)
view1=viz.add('ground.ive')
view1.setScale(5,5,5)
view1.setPosition(-200,-2000,10550)
avatar = viz.add('vcc_female.cfg')
walkAction = vizact.walkTo([0,view1,40])
avatar.addAction(walkAction)
link = viz.link(viz.MainView, view1)
link.preTrans([0,-.1,-1])
mylight = viz.addLight()
mylight.enable()
mylight.position(0, 1, 0)
mylight.spread(180)
mylight.intensity(5)
