Old 03-31-2009, 11:02 AM
Ok, I'll see if there if something we can refer you to.
Old 04-01-2009, 12:44 PM
Just want to clarify here that Terragen models and the terrapage format have no connection.
The tool that creates the terrapage format is called Terra Vista and is made by a company called Presagis. Vizard is based on OpenSceneGraph 1.2 and I'm not sure whether the most recent version of terrapage would be supported. Perhaps you could get a sample model and try it out.
Old 04-01-2009, 04:38 PM
djdesmangles djdesmangles is offline
Thanks but...
Hi Jeff,
Thanks for the informations, but I already tried to download Terra Vista at http://www.presagis.com... Still trying to find something opensource out there...
Thanks again Jeff
viz.FOREVER !!!
D!
Old 02-03-2011, 11:14 AM
I tried the 'terrapage' format models here:
http://www.triangraphics.de/index.php?1=Download&l=eng
Vizard says:
Error reading file: DataInputStream:ataInputStream(): The version found in the file is newer than this library can handle.
What version of the terrapage format does Vizard support?
Paul Elliott
WorldViz LLC
Vizard and Augmented Reality realvision Vizard 4 04-04-2008 11:59 AM
Vizard won't run wouters Vizard 5 02-05-2008 12:12 PM
wxPython with Vizard farshizzo Vizard 18 09-29-2005 09:49 AM
