Old 03-04-2009, 07:29 AM
Enlil Enlil is offline
Is there a way to get what animation an avatar is performing?
Like the topic says, is there a good way to get what animation an avatar is currently performing? GetActionRunning and GetCycleRunning will both tell you if you are running a certain animation, but querying for all animations would be an extremely awkward way to get the animation you are doing. So, is there a better function?
Christian
Old 03-04-2009, 11:13 AM
You could create a sub-class of VizAvatar, override the execute/state function, and keep the last set animation in a field variable.
Because it is possible to have multiple animations going at once, the Vizard API only has this yes/no query function. I think its good because a boolean is simpler to deal with than a list of all running animations. Usually my program logic has been interested in if a animation is running, not in what the animation actually is. For clarity, it might be nice to re-name the function 'isCycleRunning' and adding a 'getCyclesRunning' to return a list.
Avatar animation Joran Vizard 1 08-17-2007 09:44 AM
Avatar bvh animation Jerry Vizard 3 07-31-2006 03:11 PM
creating avatar animation class? Vbents Vizard 1 01-18-2006 10:34 AM
avatar animation problems jrodman Vizard 1 01-18-2006 09:12 AM
Making an avatar speak while performing an idling animation vr_boyko Vizard 1 10-05-2004 04:23 PM
