Old 01-26-2009, 06:46 PM
Here is a small example that uses the skydome plugin to show how to customize a plugin object. Usually you create your own Python module that specifies your class. In this example, create a file called SkyDome.py and add the following code to it:
class SkyDomeClass(viz.VizCustomChild):
	def myfunc(self):
		self.command(1)
viz.upgradeCustomNode('skydome.dlc',SkyDomeClass)
def addSkyDome():
	return viz.add('skydome.dlc')
The following code shows how to use your new module:
dome = addSkyDome()
dome.myfunc()
Creating a Vizard Sensor Plugin farshizzo Plug-in development 25 08-01-2019 01:24 AM
Custom Render .EXE export vaestebob Plug-in development 2 05-12-2008 08:55 AM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 11:30 AM
Creating Custom Avatar Heads farshizzo Vizard 22 09-12-2004 10:23 PM
