Old 01-09-2009, 09:17 AM
That code should give you 0 km/hour if you are not moving along the y-axis which is the height. I think you may be wanting to get the speed along the z-axis. If that's the case then just dind the difference in z coordinates rather than the y coordinates.
Old 01-09-2009, 09:29 AM
just to clarify, in the joystick navigation code, when you move the joystick on its y-axis that moves Vizard's viewpoint forward or backward which is Vizard's z axis. So to get the current z position just do
current_posZ = current_pos[2]
Old 01-12-2009, 02:20 AM
Saz Saz is offline
you're a star Jeff - thank you!! Is there any reason that I'm getting a continual drift of the viewpoint to the right though, even if I'm not using the joystick?
Old 01-12-2009, 04:23 AM
Saz Saz is offline
Don't worry Jeff - its sorted! Cheers for your help!
output data to screen Saz Vizard 1 12-19-2008 04:59 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
Data Files betancourtb82 Vizard 6 05-04-2006 02:43 PM
Obtaining Positional Data Plasma Vizard 40 04-04-2006 11:31 AM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
