Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 01-01-2009, 10:20 AM
rfam rfam is offline
thank you all.. i will wait for your help..
another question...
is there any chance to make the referentials of each body segment of the avatars visible?
Thanks again.
RM
Old 01-02-2009, 11:29 AM
Hi Rfam,
It is easy to export a skeleton as an avatar, but the animations that come with the vcc_male avatar will not work with the export unless the original skeleton file is used. We can't give out the original skeleton file, but I'll check if it's alright to export a skeleton avatar for you that can use the animations.
To export a biped skeleton as an avatar within Max, select all the bones in the biped, go to Tools ----> Snapshot , then select Mesh as the snapshot type. just take one snapshot in the biped's base pose.
Next, select the root node of the new non-biped skeleton and attach all its children into one mesh. Be careful not to attach any parts of the actual biped since this can cause crashes.
Once it is all one mesh, add a Skin modifier and add all the bones from the biped, then adjusted the skinning as you wish.
Once that is done, you can follow the exporting steps in this tutorial:
http://download.gna.org/cal3d/docume.../tutorial.html
Old 01-02-2009, 11:30 AM
Here is a sample script showing how to draw the skeletal structure of an avatar using on-the-fly points and lines:
def CreateSkeleton(avatar):
	points = []
	lines = []
	def traverse(bone):
		points.append(bone)
		for b in bone.getChildren():
			lines.append((bone,b))
			traverse(b)
	#Collect list of bones for drawing points and lines
	for b in avatar.getRootBoneList():
		traverse(b)
	#Create OTF object
	viz.startlayer(viz.LINES)
	viz.linewidth(2)
	viz.pointsize(6)
	viz.vertexcolor(viz.RED)
	for l in lines:
		viz.vertex(0,0,0)
		viz.vertex(0,0,0)
	viz.startlayer(viz.POINTS)
	for p in points:
		viz.vertex(0,0,0)
	skeleton = viz.endlayer()
	skeleton.dynamic()
	#Link each vertex to corresponding bone
	count = 0
	for b1,b2 in lines:
		viz.link(b1,skeleton.Vertex(count))
		count += 1
		viz.link(b2,skeleton.Vertex(count))
		count += 1
	for b in points:
		viz.link(b,skeleton.Vertex(count))
		count += 1
	return skeleton
model = viz.add('male.cfg',alpha=0.7)
model.state(2)
CreateSkeleton(model)
#Toggle avatar mesh on space key
vizact.onkeydown(' ',model.visible,viz.TOGGLE)
import vizcam
cam = vizcam.PivotNavigate(distance=3)
cam.centerNode(model)
Old 01-02-2009, 11:46 AM
thank you all for your attention...
Ricardo Martins
Old 01-02-2009, 04:00 PM
and there is any option to make the referentials of each body segment visible in the vizard software?
thanks,
Ricardo Martins
