Old 12-26-2008, 01:24 PM
In this code the hotspot is triggered and data is written to the file. When you click on the ball, that data is also witten to the file. Is this helpful?
room=viz.add('court.ive')
ball = viz.add('ball.wrl', pos = [0,1,5])
subject = viz.input('Who are you?')
#open file to append to
score_data = open('quest_data.txt','a')
#write to file when hotspot triggered
def onHotspot(id,x,y,z):
	print "in hot spot"
	data = 'Mr. ' + str(subject) + ' entered the hotspot.' + '\n'
	score_data.write(data)
#Callback the hotspot event.
viz.callback(viz.HOTSPOT_EVENT,onHotspot)
viz.starthotspot(1,viz.RECTANGLE_HOTSPOT_IN,0,0,.5,.5)
#write to file when object is picked
def ballPicked():
	print "ball picked"
	score_data.write('Mr. ' + str(subject) + ' picked the ball.' + '\n')
vizact.onpick(ball, ballPicked)
#close the file when program is ended
vizact.onexit(score_data.close)
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
Crashing when I select Tracker option GoldenSun Vizard 4 07-01-2008 11:06 AM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
Writing text files with executable adimov Vizard 1 03-21-2008 03:21 PM
