Old 12-23-2008, 03:58 PM
TrashcanPatrol TrashcanPatrol is offline
Writing data more than once
Hi, I tried a script to write data to a file outside of Vizard.
room=viz.add('room.wrl')
viz.collision(viz.ON)
import vizcam
vizcam.FlyNavigate()
subject = viz.input('Who are you?')
scoreLabel.score = 0
RECT3_X = -2
RECT3_Z = -2
RECT3_WIDTH = 0.5
Readboard = False
#score_data = open('quest_data','a','U')
def handlemyhotspots(id,x,y,z):
	global Readboard
	if id == BOARD:
		Readboard = True
		print 'Board has been read. +1'
		data = 'Mr. ' + str(subject) + ' was given 1 point for reading the instructions. '
	score_data.write(data)
	score_data.flush()
viz.starthotspot(BOARD,viz.RECTANGLE_HOTSPOT_IN,RECT3_X,RECT3_Z,RECT3_WIDTH,1)
That's part of the code. I'm trying to add another portion where if the player selects an object, data is written to the file score_data to say "Mr. ____ selected Item."
I can't seem to combine the two, or even get the second part of it to work by itself. Can anyone help me fix the problem?
Old 12-26-2008, 01:24 PM
In this code the hotspot is triggered and data is written to the file. When you click on the ball, that data is also witten to the file. Is this helpful?
room=viz.add('court.ive')
ball = viz.add('ball.wrl', pos = [0,1,5])
#open file to append to
score_data = open('quest_data.txt','a')
#write to file when hotspot triggered
def onHotspot(id,x,y,z):
	print "in hot spot"
	data = 'Mr. ' + str(subject) + ' entered the hotspot.' + '\n'
#Callback the hotspot event.
viz.callback(viz.HOTSPOT_EVENT,onHotspot)
viz.starthotspot(1,viz.RECTANGLE_HOTSPOT_IN,0,0,.5,.5)
#write to file when object is picked
def ballPicked():
	print "ball picked"
	score_data.write('Mr. ' + str(subject) + ' picked the ball.' + '\n')
vizact.onpick(ball, ballPicked)
#close the file when program is ended
vizact.onexit(score_data.close)
Old 01-06-2009, 03:56 PM
Ah yes! It works now! Thank you very much for your help
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
Crashing when I select Tracker option GoldenSun Vizard 4 07-01-2008 11:06 AM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
Writing text files with executable adimov Vizard 1 03-21-2008 03:21 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
