Old 12-19-2008, 02:48 AM
Saz Saz is offline
output data to screen
I'm writing the position of the joystick data to a file and I want the same information to appear on the top left of the vizard screen so that the user can see it. However I'm moving down an infinite road which is constantly updating and therefore my joystick information has to also move along with that, so I guess that I have to assign the text as a child of the road (or ground). This is what I've come up with so far
file = open( 'speed_.txt' + str(subject),'w' )
def mytimer (num):
	joy_pos = str(joy.getPosition())
	out = str(joy_pos + '\n')
	file.write(out)
	file.flush()
	print out
	#Add text as child of road
	speed = viz.add(viz.TEXT3D,joy_pos, road)
	speed.alignment(viz.TEXT_LEFT_TOP)
#Text translation will be relative to road local coordinate system
	speed.translate(-1,1,-1)
	speed.color(0,0,0)
	speed.scale(.2, .2, 2)
viz.callback( viz.TIMER_EVENT, mytimer )
viz.starttimer( 0, 0.25, viz.FOREVER )
But the data is being constantly written over rather than updating, which I'm guessing will have something to do with the write function, plus it doesn't move as I'm travelling down the road (its also in the wrong position but that's just working out the co-ordinates)
Any help would be great!
Old 12-19-2008, 04:59 PM
if you use viz.SCREEN the text will be fixed on the screen
#Add text to the screen.
text_2D = viz.addText( 'on the screen', viz.SCREEN )
text_2D.setPosition(.05, .9 ) #2D text only needs x and y.
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
text output jaclyn.bill Vizard 2 10-24-2007 06:37 AM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 08:48 AM
