Old 12-08-2008, 02:34 AM
znchb znchb is offline
Unhappy how to clear background sound of an animation
#the following program try to clean the animation-teacher and the sound,
#but I can't perform the later one, could you please help me? Thanks
viz.clearcolor(viz.SKYBLUE)
viz.add('tut_ground.wrl')
teacher = viz.add('c:\\Program Files\\WorldViz\\Vizard30\\resources\\vcc_female.c fg')
teacher.translate(1,1,1)
viz.MainView.translate(0,2,-10)
teacher.setEuler(-180,0,0)
teacher.state(14)
#speech = vizact.speak('c:\\Program Files\\WorldViz\\Vizard30\\resources\\carousel.wav ')
teacher.addAction(vizact.speak('c:\\Program Files\\WorldViz\\Vizard30\\resources\\carousel.wav '))
def clean():
teacher.clearActions()#vizact.speak)
teacher.remove()
vizact.onkeydown(' ', clean)
Old 12-08-2008, 11:04 AM
Try the following to end the sound in the middle of running a speak action. In order to preserve the indentation of your code use the code tags the next time you post some code.
teacher = viz.add('vcc_female.cfg', pos = [0,0,5], euler = [180,0,0])
teacher.state(14)
speech = vizact.speak('carousel.wav')
teacher.addAction(speech)
def clean():
	teacher.remove()
	viz.playsound('carousel.wav', viz.STOP)
Sound Looping Problem JMOwens Vizard 4 09-29-2010 09:42 PM
Stuttering sound Jerry Vizard 1 06-13-2007 12:36 PM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 05:52 PM
avatar animation problems jrodman Vizard 1 01-18-2006 09:12 AM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
