If you are constructing the geometry within the Vizard plugin, then you just need to use the conversion I mentioned in my previous post:
3D Vectors: X_VIZARD = X_OPENGL Y_VIZARD = Y_OPENGL Z_VIZARD = -Z_OPENGL Quaternion: QX_VIZARD = -QX_OPENGL QY_VIZARD = -QY_OPENGL QZ_VIZARD = QZ_OPENGL QW_VIZARD = QW_OPENGL |
(sorry I did not get back sooner on this, I did not work on this problem) This works indeed, partly. I also have to change the polygon winding, for vertex coordinates, normals and texture coordinates. But now my geometry is oriented properly. Hmm, this looks rather strange to me. You have changed the internals of osg then? Because in order to get the same results in Vizard via different ways, I have to fill the arrays in different order, inverted or not: OpenGL coord --> pure osg geometry (osg conversion) --> ive export --> Vizard and OpenGL coord --> Vizard plugin (Vizard conversion as you said) --> Vizard Can you confirm this? And also, do I need to know about other places where a conversion is needed like this? Thanks a lot Raymond |
| Thread Tools | |
| Display Modes | Rate This Thread |
| Should my PPT Machine have a Vizard license? (Urgent) | Brandyn | Precision Position Tracker (PPT) | 3 | 05-05-2008 11:06 AM |
| Vizard and Augmented Reality | realvision | Vizard | 4 | 04-04-2008 10:59 AM |
| Vizard won't run | wouters | Vizard | 5 | 02-05-2008 11:12 AM |
| Fall 2007 release of Vizard R3 | 3 D | Announcements | 0 | 10-15-2007 04:50 PM |
| vizard and java -> jython? | Johannes | Vizard | 10 | 06-28-2005 10:23 AM |
