Old 11-18-2008, 10:53 AM
You can use the <node>.getChild() command to get a handle to a sub-object by name. As long as the lightwave exporter/loader preserves the object names, this should work.
Old 11-21-2008, 06:53 AM
hosier hosier is offline
Thanks. I'm waiting for the graphics person to get back to me about the list of names for each layer.
In the mean time I did some looking around and saw the function <node3d>.getChildren that generates a list of the next level of children for an object.
There isn't an example given, so I wasn't sure what type of list it returns. Is it an array of nodes, or is it an array of names of the layers?
Aaron
Old 11-21-2008, 09:10 AM
You can right-click on the model in the resource list and select Properties. This will display a tree representing the models scene graph and it will contain the names of each node.
Lightwave avatar question electric jello Vizard 3 08-29-2006 03:44 PM
using Lightwave objects vorin Vizard 1 01-12-2005 10:15 AM
