Old 10-21-2008, 10:38 AM
I needed to add the following two lines to the top of your script in order for it to run properly:
import random
import viztask
Also, make sure you don't have any other file in the same directory as your script that is named random.py. If you do, this might conflict with the built-in random module.
Also, can you explain in more detail what behavior you are expecting? Should the box disappear after it looms, or should it go back to its original position?
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 11:23 AM
Getting object position in screen coordinates v-Salik Vizard 1 10-19-2007 04:41 PM
picking problem... k_iwan Vizard 2 07-27-2007 08:57 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
