Thanks very much for your reply, unfortunately I get an error message:
randomCube = random.choice(cubeList) AttributeError: 'module' object has no attribute 'choice' I suspect this has something to do with the way I have set this up? # Add a cube cube1 = viz.add('box.wrl') # Positions the first row of cubes cube1.setPosition(0,0) cube2 = cube1.copy() cube2.setPosition(-3,0) cube3 = cube1.copy() cube3.setPosition(3,0) # Position the second row of cubes cube4 = cube1.copy() cube4.setPosition(0,2) cube5 = cube1.copy() cube5.setPosition(-3,2) cube6 = cube1.copy() cube6.setPosition(3,2) # Position the third row of cubes cube7 = cube1.copy() cube7.setPosition(0,4) cube8 = cube1.copy() cube8.setPosition(-3,4) cube9 = cube1.copy() cube9.setPosition(3,4) # Define speed and rotation of cubes def mytimer(rotate): global angle angle = angle + (speed * viz.elapsed()) cube1.rotate(0, 5, 20, angle) cube2.rotate(0, 5, 20, angle) cube3.rotate(0, 5, 20, angle) cube4.rotate(0, 5, 20, angle) cube5.rotate(0, 5, 20, angle) cube6.rotate(0, 5, 20, angle) cube7.rotate(0, 5, 20, angle) cube8.rotate(0, 5, 20, angle) cube9.rotate(0, 5, 20, angle) # Opens file 'response.txt' in write mode file = open('reaction_time', 'a') # Sets up looming characterics for cube1 backAndFourth1 = vizact.sequence([vizact.goto(0, 0, -1, 1), vizact.goto(0, 0, 0, 1)]) # Define a function that records reaction times in response to a looming cube def SaveData(): #Data for getting values from wait conditions d = viz.Data() while True: #Wait random amount of time yield viztask.waitTime(2) # Cube 1 looming cube1.addAction(backAndFourth1) #Wait for next frame to be drawn to screen yield viztask.waitDraw(d) # Calculate reaction time displayTime = d.time #Wait for keyboard reaction yield viztask.waitKeyDown(None,d) reactionTime = d.time - displayTime # Create the output string out = str(reactionTime) + '\t''\n' # Write the string to the output file file.write(out) print 'Reaction time:',reactionTime |
| Thread Tools | |
| retrieve Object names | Geoffrey | Vizard | 11 | 12-11-2009 05:26 AM |
| Can you link the position of a tracker to the orientation of an object? | michaelrepucci | Vizard | 1 | 09-19-2008 11:23 AM |
| Getting object position in screen coordinates | v-Salik | Vizard | 1 | 10-19-2007 04:41 PM |
| picking problem... | k_iwan | Vizard | 2 | 07-27-2007 08:57 PM |
| rotate to object | jargon | Vizard | 1 | 08-08-2005 01:20 PM |
