Old 08-11-2008, 02:05 PM
I don't understand what exactly the problem is. As you move a virtual object away from the viewpoint, the on-screen stereo separation should increase. If this is the behavior you are seeing, then the stereo is working fine.
Old 08-13-2008, 01:54 PM
timbo timbo is offline
hmm, what I want is to get is the environment and the ball to look 3D but when I set the ipd to 0.6 I get two separate images on top of eachother. When the ball is really close the images are really far apart, and when the ball is really far the images are also really far apart.
If I glue the fusion distance to the ball the earlier problem is solved but the surrounding environment gets warped as the ball moves. Does that help clarify anything?
Old 08-13-2008, 02:07 PM
I still don't understand what the problem is. What you are describing is normal for 3D stereo programs. What stereo mode are you using and is it compatible with your stereo monitor? Also, are you setting the screen distance parameter? The default is 1 meter, so if you are sitting further away than 1 meter from the monitor then you will need to modify this.
vizcave and quad-buffered stereo michaelrepucci Vizard 7 11-29-2011 11:15 AM
emagin stereo vision quadro fx 570 smith11235 Vizard 5 08-05-2008 12:01 PM
3D stereo on a secondary monitor (projected wall) michaelrepucci Vizard 1 07-29-2008 11:25 AM
Monitor Modes & Vizard (problems...) tmcw Vizard 1 10-03-2007 07:29 AM
problems with see real 3d monitor bailenson Vizard 2 03-23-2006 04:00 PM
