Yeah, this works, although the crosshair doesn't fill up the whole screen, it's shown in a window like this (see attached image).
Don't you have to use Code:
viz.go(viz.FULLSCREEN) |
You don't need to go fullscreen, I just want to make sure the graphics window displays the correct image. So when you replace the crosshair texture with your own pattern, the pattern doesn't fill up the entire graphics window? Have you tried reducing the size of your pattern texture to 1024x1024? Your card might not support larger textures. Other than that, I don't know what else could be wrong with your system.
| Thread Tools | |
| Display Modes | Rate This Thread |
| How to make an image cover the view? | aznan | Vizard | 2 | 04-16-2008 12:29 PM |
| Manipulating Tracker View | Micha | Vizard | 3 | 02-25-2008 11:05 AM |
| problem with stereo mode | shivanangel | Vizard | 3 | 10-17-2006 10:58 AM |
| Only part of tiled image | vizmaster | Vizard | 5 | 09-11-2006 01:11 PM |
| keeping a 3d object in front of the view | tavaksai | Vizard | 1 | 07-07-2004 10:33 AM |
