Old 05-07-2008, 09:05 AM
Eyes that keep looking at the mirror
Hi all,
I'm trying to adjust my experiment so that the avatar that will be animated by a participant will keep looking at the mirror with its eyes. For testing purposes, I tried the 'biohead_eyes.vzf' file for a head with eyes that can move but I just can't seem to get the reflection right (so that the eyes in the mirror are looking at the participant when the participant looks in the mirror). So what I want is that the eyes will keep looking at the mirror even when the head is turned. With the Live Character plugin, the height of the eyes will be automatically adjusted to the height of the head I presume (I'm not sure)? See below for the code so far.
def addMirror(mirror,mat=None):
	#If mirror matrix is not specifed, get matrix of mirror object
	if mat is None:
		mat = mirror.getMatrix()
	#Position of mirror
	pos = viz.Vector(mat.getPosition())
	#Direction mirror is pointing
	dir = viz.Vector(mat.getForward())
	dir.normalize()
	#Quaternion rotation of mirror
	quat = mat.getQuat()
	#Create render texture
	tex = viz.addRenderTexture()
	#Create render node for rendering reflection
	lens = viz.addRenderNode(size=[1024, 1024]) #set to [1024,1024] in the lab!
	lens.attachTexture(tex)
	lens.setInheritView(True,viz.POST_MULT)
	lens.disable(viz.CULL_FACE,op=viz.OP_SET_OVERRIDE)
	#Setup reflection matrix
	rot = viz.Matrix.quat(quat)
	invRot = rot.inverse()
	lens.setMatrix(viz.Matrix.translate(pos*-1.0)*invRot*viz.Matrix.scale(1,1,-1)*rot*viz.Matrix.translate(pos))
	#Setup reflection clip plane
	s = -viz.sign(viz.Vector(dir) * viz.Vector(pos))
	plane = vizmat.Plane(pos=pos,normal=dir)
	dist = plane.distance([0,0,0])
	lens.clipPlane([-dir[0],-dir[1],-dir[2],s*dist+0.001])
	#Project reflection texture onto mirror
	mirror.texture(tex)
	mirror.texGen(viz.TEXGEN_PROJECT_EYE)
avatar = viz.add('vcc_female.cfg')
light_avatar = viz.addLight()
face = avatar.face('biohead_eyes.vzf')
l_eye = face.getchild('geom_0')
r_eye = face.getchild('geom_1')
#Mirror surface
mirrorsurface = viz.addTexQuad()
mirrorsurfaceposition = [0, 1.25, .5] #Y,Z,X
mirrorsurface.setPosition(mirrorsurfaceposition)
mirrorsurfacerotation = [0,0,0] #Z,Y,X
mirrorsurface.rotate(mirrorsurfacerotation)
mirrorsurface.scale(2,3)
light_mirror = viz.addLight()
light_mirror.position(mirrorsurfaceposition[0],mirrorsurfaceposition[1],mirrorsurfaceposition[2]+2,0)
light_mirror.direction(mirrorsurfacerotation[0]/180, mirrorsurfacerotation[1]/180, mirrorsurfacerotation[2]/180)
#Apply reflection to mirrorsurface
m = viz.Matrix()
m.setPosition(mirrorsurface.getPosition(viz.ABS_GLOBAL))
m.setEuler(mirrorsurfacerotation[0]-180,-mirrorsurfacerotation[1], mirrorsurfacerotation[2]) #Z,X,Y
addMirror(mirrorsurface,m)
def mytimer(num):
	bone = avatar.getBone('Bip01 Head')
	pos = bone.getPosition()
	r_eye.lookat(1,pos[1],3 ,0,viz.ABSOLUTE_WORLD)
	l_eye.lookat(1,pos[1],3 ,0,viz.ABSOLUTE_WORLD)
viz.starttimer(0,0,viz.FOREVER)
Old 05-07-2008, 03:42 PM
Jerry Jerry is offline
I just happen to have worked on that and here's what I
came up with.
Old 05-07-2008, 04:38 PM
Or if you like that other way of reflecting things here's version 2.
Old 05-13-2008, 05:39 AM
Thanks for your scripts, that was what I was looking for. Btw I like te way of mirroring in you first script, but that kind is impossible if the mirror is not on the edge of the environment. That's why I use the other method. Thanks!
Mirror issues Frank Verberne Vizard 2 04-08-2008 10:37 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 05:52 AM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 08:21 AM
Heads with geometries for eyes and mouth Karla Vizard 2 03-14-2008 11:39 AM
Getting access to the eyes of CFG avatars bailenson Vizard 1 06-18-2004 04:55 PM
