Old 05-06-2008, 09:35 AM
1) You can publish your script to an EXE by selecting File -> Publish as EXE from the menu. Just follow the on screen instructions from there.
2) Here is some code that will resize the main window so the second window does not cover it up. I also added a background window that will fill up the rest of the empty space in the window.
#Add window to top
top_view = viz.addView()
top_view.setPosition([0,10,0])
top_view.setEuler([0,90,0])
top_window = viz.addWindow(pos=(0,1),size=(0.2,0.2),view=top_view)
#Reduce size of main window
viz.MainWindow.setSize([0.8,1])
viz.MainWindow.setPosition([0.2,1])
#Add background window
background = viz.addWindow(pos=[0,1],size=[1,1])
background.setView(view=viz.addView(scene=viz.addScene()))
background.drawOrder(-10)
Old 05-06-2008, 03:50 PM
gakusei08 gakusei08 is offline
Send a message via Yahoo to gakusei08
thanks a lot farshizzo,..
now i get resize the main window..
but when i add script for background window,nothing has change?? how can i add background to fill up the rest of the empty space of the window? (example for add image)
Old 05-07-2008, 09:47 AM
You can add a fullscreen quad to the background scene using the following code:
texture = viz.add('ball.jpg')
back_scene = viz.addScene()
quad = viz.addTexQuad(viz.SCREEN,scene=back_scene,scale=(12.8,10.24,0),pos=(0.5,0.5,0))
quad.texture(texture)
background.setView(view=viz.addView(scene=back_scene))
Publish as EXE - Introduction tobin Vizard 19 02-12-2009 02:51 AM
Vizard file save as .exe urgent!!! tacbob Vizard 2 05-10-2007 01:05 AM
