Old 04-29-2008, 08:46 AM
Andy Andy is offline
stereo-projection
Hello, I have question regarding stereo-projection.
I would like to produce the image for the right and left eye separately on one client, with the aid of an nvidia-quadro-card. Furthermore I would like to use a curved-screen so I need a distortion-correction and edge-blending for a multi-channel projection.
Is there a chance to do this with Viziard directly?
If not, I will have to use an aditional Software-tool from another vendor, which archives this based on OpenGL- and DirectX-commands directly on the render-engine. This tool seems to have a very high-performance but there is a problem. The tool takes the openGL-output of a window and warps this into the configured projection.
If I want to transform the image for the right and left eye on one Client I have to calculate the images each within separate windows. If I use the command “viz.STEREO” I get one big image with the information for the left and right eye. Is there a possibility to get two separate images in stead of one?
Also I’m open to other solutions regarding this problem.
Old 04-29-2008, 07:54 PM
I've attached a sample script that renders the scene in stereo to a texture and displays it onto a tessellated quad. You can implement the _distortTexCoord function to return distorted texture coordinates, right now it simply returns undistorted coordinates.
viz.go(viz.STEREO)
#Initialize environment
viz.clearcolor(viz.GRAY)
viz.add('gallery.ive')
#Hide scene so it is not rendered to frame buffer
viz.MainScene.visible(0,viz.WORLD)
#Distortion grid constants
GRID_WIDTH = 100
GRID_HEIGHT = 100
GRID_STEP = 5
def CreateLensDistortion(eye):
	#Create render texture
	tex = viz.addRenderTexture()
	#Determine size of window
	width,height = viz.window.getSize()
	width /= 2
	#Create node to render scene to a texture
	lens = viz.addRenderNode(size=[width,height])
	lens.attachTexture(tex)
	lens.disable(eye)
	#Create node to displayed rendered texture to screen
	overlay = viz.addRenderNode()
	overlay.setOrder(viz.POST_RENDER)
	overlay.setHUD(0,GRID_WIDTH,0,GRID_HEIGHT)
	overlay.disable(eye)
	overlay.disable(viz.LIGHTING)
	def _distortTexCoord(x,y):
		#TODO: Distort texture coordinates given (x,y) vertex coordinates
		return x / float(GRID_WIDTH) , y / float(GRID_HEIGHT)
	#Create quad with distorted texture coordinates to display render texture
	viz.startlayer(viz.QUADS)
	for i in range(0,GRID_WIDTH,GRID_STEP):
		for j in range(0,GRID_HEIGHT,GRID_STEP):
			viz.texcoord(_distortTexCoord(i,j))
			viz.vertex(i,j,0)
			viz.texcoord(_distortTexCoord(i+GRID_STEP,j))
			viz.vertex(i+GRID_STEP,j,0)
			viz.texcoord(_distortTexCoord(i+GRID_STEP,j+GRID_STEP))
			viz.vertex(i+GRID_STEP,j+GRID_STEP,0)
			viz.texcoord(_distortTexCoord(i,j+GRID_STEP))
			viz.vertex(i,j+GRID_STEP,0)
	quad = viz.endlayer(parent=overlay)
	quad.texture(tex)
#Create lens distortion for left/right eyes
CreateLensDistortion(viz.RENDER_LEFT)
CreateLensDistortion(viz.RENDER_RIGHT)
Old 05-02-2008, 03:23 AM
Thank you farshizoo for your reply. It seems to work very well but I had a Problem. Can you tell my why I get a complete white Screen if I use “viz.addRenderNode(size=[width,height])”? By using (size=1024,1024) it works also by viz.addRenderNode(scene = viz.MainScene). Is it ok if I use (scene = viz.MainScene)?
For my fist test I use static data’s for the texture coordinates. Have anybody a code for realtime-moving texture coordinates based on an x*x-Grid?
Old 05-02-2008, 04:42 PM
By default the render node is added to the main scene, so specifying that in your code is redundant. Your graphics card might not support render textures of size [1024,1024]. Try adding the following line after you create the render node to see if it helps:
lens.setBuffer(viz.RENDER_FRAME_BUFFER)
This will use the standard frame buffer to copy to the render texture, instead of FBOs. Also, make sure your graphics card driver is up to date.
8800 ultra stereo driver Dave Vizard 21 10-25-2009 10:25 AM
anaglyphic stereo, backprojection & screendistance malte Vizard 4 02-23-2008 06:48 AM
stereo projection issue asimbh Vizard 3 10-05-2007 10:22 AM
quad buffered stereo? halley Vizard 2 10-19-2005 12:28 PM
SeeReal stereo with separate scenes Jerry Vizard 2 10-18-2005 12:02 PM
