Old 04-24-2008, 09:51 AM
nige777 nige777 is offline
RE: Right answer, wrong question!
Thanks for the suggestion, it works really well. Unfortunately I posted the question when I was half asleep, so I apologies for the fact that I will now have to ask you a revised question. I actually need to be able to dismount the the truck and move around. I control the truck with a joypad with the head ori of the view set to mouselook and envisage controlling the view in the same way when I dismount. Here's the joypad script I'm using to drive the FLT:
#Use joystick to control FLT navigation
def UpdateMovement():
    #Get the joystick position
    x,y,z = joy.getPosition()
    #Get the twist of the joystick
    twist = joy.getTwist()
    #Using the z value off the twist control for up and down
    if abs(y) > 0.3 or abs(y) < -0.3:
        SetThrottle(-y)
    if abs(y) <0.3 and abs(y) >-0.3:
        SetThrottle(0)
    if abs(twist) > 0.2 or abs(twist) < -0.2:
        steer(twist*70)
        steerWheel(-twist*65)
    elif abs(twist) < 0.2 or abs(twist) > -0.2:
        steer(0)
        steerWheel(0)
#UpdateJoystick every frame
vizact.ontimer(viz.FASTEST_EXPIRATION,UpdateMovement)
So what I think I am asking is how do I mount and dismount from the truck while using the same controls to manipulate the main view.
Thanks for your patience,
Nige
Old 04-28-2008, 01:33 PM
I'm not exactly clear on what you are trying to accomplish. It seems like you just need to disable the UpdateMovement function while you are dismounted from the truck, and enable it when you are mounted. Let me know if I misunderstood your question.
Old 05-07-2008, 03:39 PM
Hi fashizzo,
Yes, you are quite right, I need to disable the UpdateFLTMovement() function whilst dismounted from the truck. However, I now have 2 functions, one for moving the truck, one for moving the view, but am unable (in my sleep deprived state ) to switch toggle between them. I have tried all manner of enable and disable combinations - but to no avail. I feel that (once again) I am missing something really simple
All help gratefully received
Old 05-08-2008, 06:50 AM
RE:Ignore me!
Please disregard the last post - I have had some sleep and my brain has started working again
I just put the two functions in a timer and just call or kill whichever one I want!
Cheers
Nige
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 11:15 AM
Stereo Overlap question JMOwens Vizard 2 01-08-2008 09:54 AM
viztask question asimbh Vizard 1 11-20-2007 10:12 AM
Another color question mjabon Vizard 4 07-31-2007 04:04 PM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 08:08 PM
