Old 03-14-2008, 08:35 AM
Sensor callback to the wii mote buttons
I read over the tutorial script and I created two callbacks for a sensor up and sensor down event.
The tutorial uses vizact commands,
I am not so much a fan of these and I was wondering if I can do button checking the 'classic' way:
if b = wii.BUTTON_A:
How do I go about doing this? I'm not sure what kind of object is being returned in the callback functions.
George
Old 03-14-2008, 09:25 AM
The Event Reference section of the docs explains how to use viz.SENSOR_DOWN_EVENT and viz.SENSOR_UP_EVENT. These will be triggered when a sensor button is pressed/released.
Old 03-14-2008, 09:41 AM
Yes,
I have taken a look at this section and it does cover how the sensor_down and up event work.
However, in the example given it maps a button from a joystick to a variable and then checks if that is the object in question.
With the wiimote, you have a section in the reference which specifies
<wii>.BUTTON_LEFT
<wii>.BUTTON_A
when setting up my conditional statement what do I put in there to check the event.
I looked and saw that an event is being returned as 'e' in the callback, then when I did e.object, it told me : __main__._WiimoteSensor(0)
So it is returning a WiimoteSensor, however how do I access what button from the sensor is being pressed? All buttons return the same __main__._WiimoteSensor(0) for the sensor, so I need to go a level deeper to do my check. How do I do this?
Thank You,
George
Old 03-14-2008, 09:45 AM
Wow, I'm sorry I'm a complete and total idiot.
The answer is right there in the DOC staring me in the face.
I think I've been at a computer for too long.
Thanks again!
George
Strange Wii Mote error... shivanangel Vizard 8 02-18-2009 12:32 PM
Using Window Buttons Uttama_vizard Vizard 2 01-16-2008 10:25 AM
Buttons Not rendering to both Eyes in 3d shivanangel Vizard 2 05-24-2007 06:58 AM
Vanda(Wanda) buttons giancamati Vizard 1 12-07-2006 10:21 AM
