Old 02-18-2008, 06:38 AM
djdesmangles djdesmangles is offline
Lightbulb lip-synching + Progress Bar
Hello Wizards !!
The "viz.ACTION_END_EVENT" is working fine. Now I would like to optimize one of my functions.
1) My Avatar is lip-synched with a .wav file.
2) I got a progress bar displaying to the user the position in the .wav file while the Avatar is speaking.
So, to do that, I've loaded the .wav for the Avatar with the vizact.speak('intro.wav'). But, for the Progress Bar, I must loaded the file again as a VizAudio object to access the getTime() and the getDuration() functions. It's working, but is there a better way to do that ?
viz.FOREVER,
D.
Old 02-19-2008, 02:30 PM
Unhappy You're there ??
Hello ?
I guess that you've forgot about me...
D.
Old 02-19-2008, 03:26 PM
Don't worry, we haven't forgot about you. Yesterday was a holiday.
Here is sample code that will update a progress bar while a speech action is running. It works by starting a timer when the speech begins. The timer uses the action instance to determine the current time of the speech.
#Create avatar
avatar = viz.add('female.cfg',pos=(0,0,1),euler=(180,0,0))
#Create speech action
speak = vizact.speak('speech.wav',sync=True)
#Create progress bar
progress = viz.addProgressBar('',pos=(0.5,0.1,0))
#Function that will update progress of speech while it is running
def updateSpeechProgress(progress,instance):
	progress.set( instance.elapsed / instance.length )
#Start update timer when speech action begins
def onActionBegin(e):
	if e.object is avatar and e.action is speak:
		avatar.speechProgress = vizact.ontimer(0,updateSpeechProgress,progress,e.instance)
viz.callback(viz.ACTION_BEGIN_EVENT,onActionBegin)
#Stop update timer when speech action ends
def onActionEnd(e):
		vizact.removeEvent(avatar.speechProgress)
viz.callback(viz.ACTION_END_EVENT,onActionEnd)
#Start speech when spacebar pressed
vizact.onkeydown(' ',avatar.runAction,speak)
Old 02-21-2008, 01:37 PM
Talking Coooool !!!
Yeah Man !!!
I'll try it !!! Thanks !!
viz.FOREVER !!
D.
Avatars creation........ k_iwan Vizard 23 06-02-2007 05:35 AM
Progress bar Jerry Vizard 1 10-16-2006 12:22 PM
