Old 11-29-2007, 03:05 PM
I'm not sure, it might be a framerate issue. Did the sample script I posted above give you better results?
Old 11-30-2007, 08:37 AM
Elittdogg Elittdogg is offline
The sample script didn't really do anything. Maybe I'm not implementing it correctly, but I can't seem to get consistent results. When I'm running a script other than just that simple script the frame rate fluctuates around 49. Anyway, is there a way that I'm supposed to put your sample script within the code I have to make it work? Because what I did didn't do anything.
Old 11-30-2007, 02:45 PM
Cool
Did you place your code for collecting samples in the DoSample function? That function will be called at the specified rate.
Old 12-03-2007, 08:39 AM
This is what I did:
class SampleRate(viz.EventClass):
	def __init__(self,rate,func):
		viz.EventClass.__init__(self)
		self.rate = rate
		self.func = func
		self.lastSampleTime = 0.0
		self.callback(viz.TIMER_EVENT,self.onTimer)
	def onTimer(self,num):
		now = clock()
		while (now - self.lastSampleTime) >= self.rate:
			self.func()
			self.lastSampleTime += self.rate
	def start(self):
		self.killtimer(0)
		self.lastSampleTime = clock()
		self.starttimer(0,0,viz.FOREVER)
	def stop(self):
		self.killtimer(0)
def DoSample():
	#Collect sample here
	flock1 = viz.add('flockofbirds.dls')
	flock1.command(6)
	tracking_data = open('openloopsine_complex/headdata_'+ str(Subnum) + " " + str(Trial) + '.txt', 'a')
	def mytimer(num):
		if num == 0:
			global AMPLITUDE, TOTALCYCLES, X1, X2, samples
			data1 = flock1.get()
			HEADLAT = data1[0]
			HEADVERT = data1[1]
			HEADAP = data1[2]
			HEADYAW = data1[3]
			HEADPITCH = data1[4]
			HEADROLL = data1[5]
			head_data = str(Subnum) + '\t' + str(Trial) + '\t' + str(HEADAP) + '\t' +str(HEADLAT) + '\t' +str(HEADVERT) + '\t' +str(HEADYAW) + '\t' +str(HEADPITCH) + '\t' +str(HEADROLL) +'\n'
			tracking_data.write(head_data)
		if num == 4:
			xmove = AMPLITUDE*math.sin(2*(math.pi/180)*X1) + AMPLITUDE*math.sin(2.5*(math.pi/180)*X1) + AMPLITUDE*math.sin(3.5*(math.pi/180)*X1) + AMPLITUDE*math.sin(1.75*(math.pi/180)*X1) + AMPLITUDE*math.sin(2*(math.pi/180)*X1) + AMPLITUDE*math.sin(2.5*(math.pi/180)*X1) + AMPLITUDE*math.sin(3*(math.pi/180)*X1) + AMPLITUDE*math.sin(2.5*(math.pi/180)*X1)+ AMPLITUDE*math.sin(2*(math.pi/180)*X1) + AMPLITUDE*math.sin(1.75*(math.pi/180)*X1)
			X1 = X1 + 1
			sphere.translate(0,1.8,.2+.3*xmove, viz.ABSOLUTE)
		if num == 3:
			viz.quit()
	pass
#Call function 'DoSample' at rate of '1/30.0'
sampler = SampleRate(1/30.0,DoSample)
#Start the sampler
sampler.start()
def onkeydown(key):
	if key == ' ':
		viz.starttimer(0,(1.0/30.0), viz.FOREVER)
		viz.starttimer(4,(1.0/30.0),viz.FOREVER)
		viz.starttimer(3,60,1)
I think my problem is that I don't know how to embed "mytimer" within "dosample." Because even when I try different indentations it doesn't start at all. And it keeps giving me this error message:
File "<string>", line 12, in ?
File "openloopsine(complex)_adjusted timer3.py", line 111, in ?
NameError: name 'mytimer' is not defined
So I'm assuming that it's not registering it as it's own identity/function but I'm a bit confused as to how that would work. Would I have to change "dosample" to a class? And if so, would the rest stay the same?
Old 12-04-2007, 09:37 AM
You only need to place your timer code inside the DoSample function. Everything else should be outside the function. So it should looke something like this:
def DoSample():
	HEADLAT = data1[0]
	HEADVERT = data1[1]
	HEADAP = data1[2]
	HEADYAW = data1[3]
	HEADROLL = data1[5]
Flock of Birds recognized, but no data sent sjroorda Vizard 9 03-01-2016 08:48 PM
Using vrpn_server with Flock of birds sylvain Precision Position Tracker (PPT) 3 11-30-2007 09:45 AM
Flock of Birds Elittdogg Vizard 9 10-02-2007 01:53 PM
Flock of birds extended range problem theuberk Vizard 4 07-30-2007 09:31 AM
Adding more than one Flock of Birds asimbh Vizard 3 12-15-2006 01:48 AM
