Old 10-24-2007, 01:30 PM
Here's a modified version of the script that will always place the glove in front of the user. You can use other gestures to control left/right movement. Or, if you have an orientation tracker device, such as the Intersense IneriaCube, you could use that to steer the viewpoint as well.
import hand
#Identify the data glove's port.
PORT_5DT = 1
#Add the 5DT sensor
sensor = viz.add('5dt.dls')
##Create a hand object from the data glove
overlayView = viz.addView()
overlayView.setScene(4)
overlay = viz.addWindow(pos=(0,1),size=(1,1),clearMask=viz.GL_DEPTH_BUFFER_BIT,view=overlayView)
glove = hand.add(sensor,hand.GLOVE_5DT,scene=4,pos=(0,1.5,1.5),euler=(0,-90,0))
#Initialize world
viz.clearcolor( viz.GRAY )
ground = viz.add( 'tut_ground.wrl' )
def UpdateView():
	gesture = glove.getGesture()
	if gesture == hand.GESTURE_INDEX_FINGER:
		#Index finger point
		viz.MainView.move( 0, 0, 1*viz.elapsed())
	elif gesture == hand.GESTURE_FIST:
		#Fist
		viz.MainView.move( 0, 0, -1*viz.elapsed())
vizact.ontimer(0,UpdateView)
