Old 10-23-2007, 04:35 PM
I found the avatars to be a bit dark when disabling the head light and using an overhead light. I fixed this by increasing their emissive color
viz.move([0, 0, -1])
l = viz.addLight()
l.position(0,1,-.2,0)
avatar = viz.add('vcc_female.cfg', euler=[180,0,0])
avatar.state(1)
avatar.color([1]*3)
avatar.ambient([.6]*3)
avatar.emissive([.2]*3)
avatar.specular(0,0,0)
Paul Elliott
WorldViz LLC
Old 09-07-2010, 11:13 AM
Darkmax Darkmax is offline
im having this issues, and i solved with this
avatar.color(1,1,1)
avatar.ambient(0.6,0.6,0.6)
avatar.emissive(0,0,0)
but is there a way to set this on 3ds max to just import the model in vizard without making a change to the avatar?, just like the vcc_male that just you have to import it and thats it
Old 09-07-2010, 06:51 PM
avatar.color(1,1,1)
The way to do it through max would be to write a maxscript that goes through all the max files in a directory and changes the values in all the materials to what you need. The attached zip has a maxscript which should give you a good starting point.
