Hi Farshi...
My scene is empty. My objects are rendered only when I remove them from the Impostor Helper... Thanks, viz.FOREVER D. |
Which version of OSGExp are you using? Can you try exporting a sample file to the .osg format and post it here? You don't need to post the textures, I just want to examine the .osg file to make sure it is correct. |
OSG file...
Yo !!
I'm using OSG Exporter 0.9.3. I've posted the osg file to... See ya later... viz.FOREVER, D. |
It looks like the impostor is not being exported at all. When exporting the model, did you check "Helpers" under the "Export to Scene" section of the export dialog? |
Export Dialog screenshot
Hello Farshi:
I send you a screenshot of the export diag. See ya !! viz.FOREVER D. |
Hello Farshi,
I've sent you a screenshot of my export diag... Did you find something ? viz.FOREVER, D. |
Everything looks good. I'm not sure what is going on. I'm going to have our modeler test this out to see if it works here. |
| Thread Tools | |
| Display Modes | Rate This Thread |
