I just tested your script here, running one server with two clients and it worked fine. You said that server to client communication does not work. Have you tried a simple viznet example that does not use sendAll, to make sure that this is not a problem with your network setup? I've included a very basic viznet example. In this example, whenever a client presses the spacebar their background color should change. Also, the server will print out a message every time a client connects/disconnects. If this does not work then there might be a problem with your network setup. SERVER SERVER SERVER SERVER Code:
import viznet
#Create custom event IDs
CLIENT_KEYDOWN = viznet.id('ClientKeyDown')
SET_CLEAR_COLOR = viznet.id('SetClearColor')
#Start server
viznet.server.start()
colors = [viz.RED,viz.BLUE,viz.BLACK,viz.ORANGE,viz.YELLOW,viz.GREEN,viz.GRAY]
curColor = 0
#When client connects, send them current color
def onStartClient(e):
viznet.server.sendClient(e.sender,SET_CLEAR_COLOR,color=colors[curColor])
print '** Client joined:',e.sender
viz.callback(viznet.CLIENT_CONNECT_EVENT,onStartClient)
#Print out when client leaves
def onStopClient(e):
print '** Client left:',e.sender
viz.callback(viznet.CLIENT_DISCONNECT_EVENT,onStopClient)
#When client presses space key, change color and notify all clients
def onKeydownClient(e):
global curColor
if e.keydown == ' ':
curColor = (curColor + 1) % len(colors)
viznet.server.send(SET_CLEAR_COLOR,color=colors[curColor])
viz.callback(CLIENT_KEYDOWN,onKeydownClient)
import viznet
#Connect to server
viznet.client.connect(viz.input('Enter Server Name'))
#Send message to server when space key is pressed
vizact.onkeydown(' ',viznet.client.send,CLIENT_KEYDOWN,keydown=' ')
#Change color on server event
def onClearColorClient(e):
viz.clearcolor(e.color)
viz.callback(SET_CLEAR_COLOR,onClearColorClient)
#Print out message if disconnected from server
print '** Disconnected from server'
viz.callback(viznet.SERVER_DISCONNECT_EVENT,onStopClient)
| Thread Tools | |
