Old 11-14-2003, 01:13 PM
hotspur1 hotspur1 is offline
problem starting/stopping auto tracking
The documentation says that I can start and stop the automatic tracking using the following notation
viz.tracker(viz.START) or viz.tracker(viz.STOP)
Unfortunately for me, this doesn't work.
I have an IS-600 and am using the intersense.dls plug-in provided with Vizard version 2.12 (patched version for the callback problem). I initialize the tracker as usual with
trk = viz.add('intersense.dls')
Does this feature work yet? Is there a workaround? I would like to do an experiment comaring head tracking on or off, so to be able to switch on the fly would be most useful.
Old 11-14-2003, 01:31 PM
You're right, this feature has not been implemented yet. There is a workaround. To stop tracking perform the following:
viz.get(viz.MAIN_VIEWPOINT).unlink(0)
This will be fixed in the next version though.
Old 11-14-2003, 01:48 PM
Great - but to start the tracking again, do I just issue the viz.tracker() command again?
Old 11-14-2003, 01:52 PM
Yeah, issuing the tracker command should work again. Thanks for pointing out this problem.
