Old 02-05-2007, 07:39 AM
glepoura glepoura is offline
5DT left and right glove
Is there an example of using a pair of gloves? I have been experimenting with the hand tutorial, but it includes a cfg file for the right hand only...
Best Regards,
George
Old 02-05-2007, 02:57 PM
Use the <hand>.leftHand method to make the had object a left hand.
Old 02-05-2007, 02:58 PM
If you use Vizard 3.0 then you simply do the following to convert a hand into a left hand:
myHand = hand.add(sensor)
myHand.leftHand()
For Vizard 2.5 you can do the following instead:
myHand.scale(-1,1,1)
myHand.disable(viz.CULL_FACE)
Old 02-06-2007, 04:41 AM
Great, Thank you,
GL
