Old 09-13-2006, 08:32 AM
Not sure but here are some possible problems:
--One can't move the headset when connecting
--No other programs can be connected to headset
--Need to turn headset on with button
Paul Elliott
WorldViz LLC
Old 05-31-2007, 10:37 AM
It seems that sometimes Vizard cannot connect to the eMagin after its USB cable has been unpluged and pluged back in. To fix this re-run the setup2k.exe in the install stuff folder of the zip when the eMagin is pluged in.
Paul Elliott
WorldViz LLC
Old 07-26-2007, 11:00 AM
New eMagin sensor driver release. This .dls file keeps the display from turning off after 5 minutes.
Paul Elliott
WorldViz LLC
Old 09-28-2007, 11:36 AM
I have attached the latest Vizard eMagin driver and modified the installation instructions.
Installing Emagin for Vizard:
1. Install the Emagin SDK by downloading the SetupWizard from here:
http://www.3dvisor.com/support.php
2. Run the Setup Wizard and install the software.
3. Plug in the eMagin USB cable.
4. Install the eMagin USB drivers by pointing the Windows hardware installer to
C:\Program Files\eMagin\drivers
5. You can now access the orientation data of the eMagin in Vizard:
viz.add('gallery.ive')
sensor = viz.add('emagin.dls')
viz.link(sensor, viz.MainView)
Paul Elliott
WorldViz LLC
Old 10-31-2007, 10:06 AM
By the by, the latest eMagin.dls driver is included in the latest Vizard release. So all you need to do is install the SetupWizard.
Paul Elliott
WorldViz LLC
Old 10-31-2007, 10:11 AM
You can also directly control the eMagin's display via the "Lab Tool" utility available on the eMagin support download page.
Paul Elliott
WorldViz LLC
Old 04-10-2008, 10:10 AM
The latest eMagin driver is included in the Vizard installer. No need to use the one attached to this thread.
Paul Elliott
WorldViz LLC
