Old 06-02-2006, 06:55 AM
halley halley is offline
A timer starts whenever you call viz.starttimer(), so your goal is to decide when it's appropriate to make that call.
Something like this sketch (this is not tested code):
timer_one = False
def mytimer(num):
	if num == 0:
		if not timer_one and viz.get(viz.FRAME_TIMESTAMP) > 5.0:
			timer_one = True
			viz.starttimer(1, 0, viz.PERPETUAL)
		# do other timer-zero stuff
	if num == 1:
		# do other timer-one stuff
viz.callback(viz.TIMER_EVENT, mytimer)
viz.starttimer(0, 0.01, viz.FOREVER)
[ e d h a l l e y ]
I'm just a user, not a representative of WorldViz. Hope I've been helpful.
Old 06-02-2006, 09:12 AM
paulpars paulpars is offline
error
when I try to run that I get this error:
AttributeError: 'module' object has no attribute 'FRAME_TIMESTAMP'
Old 06-02-2006, 09:43 AM
You can also use the Python time module.
import time
#Gives number of seconds since program start
print time.clock()
Paul Elliott
WorldViz LLC
