Old 05-04-2006, 11:00 AM
Talking
PERFECT! Thanks for the help. Can I do the same thing with the object they are holding? Since the object is a different array that's merely linked to this one, how do I identify the object in hand? Basically if it's a gun or a cell phone I just need to specify that it's "non-threatening". If it's a gun then i have to specify that it's "threatening".
Thanks again!
Old 05-04-2006, 11:07 AM
In python, you can add as many attributes to an object as you wish. So to determine if an object is "threatening" simply give it an attribute which says so.
donut = viz.add('donut.wrl')
donut.isThreatening = False
donut.isDelicious = True
gun = viz.add('gun.wrl')
gun.isThreatening = True
gun.isDelicious = False
Old 05-04-2006, 12:35 PM
Ok, I understand that part, but my problem is how do I let the program know that the avatar is holding that object. In the MoveBullet function shown above, I identify the avatar "attribute" as info.object.tag, but how do I do that with the object they are holding. Can I do something like info.object.tag.linkbone to identify each object of each avatar?
for x in range(0,3):
 if x == 0:
  male = viz.add(people[0])
  male.scale(.1,.1,.1)
  link = viz.add(viz.GROUP)
  myphone = link.add(objects[0])
  myphone.scale(.0005,.0005,.0005)
  male.linkbone(link,'skel_HandR')
  male.tag = 0
  myphone.threatening = TRUE
 elif x == 1:
  male = viz.add(people[1])
  myphone = link.add(objects[1])
  myphone.translate(0,-.25,.17)
  myphone.rotate(180)
  male.linkbone(link,'skel_Neck')
  male.tag = 1
  myphone.threatening = FALSE
 elif x ==2:
  male = viz.add(people[2])
  myphone = link.add(objects[2])
  myphone.scale(.0008,.0008,.0008)
  myphone.rotate(66.51,151.49,86.01)
  myphone.translate(-0.02,0.04,0.02)
  male.linkbone(link,'skel_HandRF')
  male.tag = 2
 male.translate(3*x,-10,10)
 male.rotate(180)
 #Add the avatar to the waiting and lemming list
 waitlist.append(male)
 characters.append(male)
Old 05-04-2006, 12:55 PM
As I already mentioned, you can add any attribute to an object. So just add an attribute to each avatar which contains a list of the objects it is holding.
male.holding = [gun,phone,bowlingBall]
print 'Avatar is holding',info.object.holding
Old 05-04-2006, 02:13 PM
Thank you, worked GREAT
