Old 03-17-2006, 04:19 AM
perselletje perselletje is offline
license question
I have some questions about the floating license system of Vizard. We plan to use a router system to connect the client pc with the server pc, since the client pc has not virusscanner or firewall, so we don't want to connect it to the internet. We only want the ports that come from the server pc to be able to pass through the router. So here are my questions:
Which port ranges are used by the server pc to connect with the client?
And which type of port is used, UDP or TCP?
Thanks!
Old 03-17-2006, 12:23 PM
The server uses UDP.
When it starts it will print out the following line:
Locator started on UDP port XXXXX
This is the port it will be connected on.
