Old 03-01-2006, 02:28 PM
Well, I wouldn't really call this a problem. What you are asking is kind of impossible to do. You want the object to appear directly at the center of the crosshair for BOTH the left and right eye. Also, keep in mind that the duckcourt example was not intended to be used in STEREO mode. Having GUI objects, such as the crosshair, won't work correctly in STEREO.
Old 03-02-2006, 05:07 PM
I think I'm not doing a very good job of communicating what we are trying to do. I spoke to another person that works here in the lab and he said that he remembered hearing that this software was used for military shooting simulations. Our application is similar. I'm thinking that if the military does it, the "gun" should be relatively accurate. For some reason ours isn't. I've attached the entire prototyped code for your reference. Any suggestions? If after looking at this code you still think it's impossible to get proper accuracy, then I'll move on and try something else. As I mentioned before, it works w/o stereo mode, but not with.
import vizmat
import math
import time
viz.go(viz.STEREO)
#arrays
avatars = []			#for avatars
collidables = []		#for collidable objects
bullets = []			#for number of balls
#constants
NUM_BULLETS = 3			#number of balls in the array
nextBullet = 0			#index for the next ball in the array
BULLET_SPEED = 250		#speed in meters/secs of the bullet
ANIMATION = 1			#animation ID
NUM_AVATARS	= 5			#the number of avatars
court = viz.add('terrain1.wrl')
court.scale(0.5,0.5,0.5)
court.rotate(0,1,0,-90)
court.translate(-5,0,-10)
court.appearance(viz.MODULATE)
court.disable(viz.LIGHT0)
#Add a crosshair
crosshair = viz.add(viz.TEXQUAD,viz.SCREEN)
crosshair.texture(viz.add('crosshair.tif'))
#Create six avatars
def startAvatar(location):
	global court
	for i in range(NUM_AVATARS):
		newX = -math.cos(-2*i+15) * 2
		newZ = math.sin(i^2+1) * 2
		male = viz.add('male.cfg')
		male.translate(newX,0,newZ)
		male.rotate(180,0,0)
		avatars.append(male) #Save avatar in list
startAvatar(court)
def onmousedown(button):
		node = viz.pick() #Get object that was clicked
		if node in avatars: #Check if object is one of the avatars
			node.execute(7) #Execute the "shot" animation
			#Create action to wait for the animation duration then freeeze the avatar
			WaitThenFreeze = vizact.sequence( vizact.waittime(node.getduration(7)-.1), vizact.speed_node(0) )
			node.add(WaitThenFreeze) #Add the action to the avatar
viz.callback(viz.MOUSEDOWN_EVENT,onmousedown)
for x in range(0,NUM_BULLETS):
	#create a bullet that is initially hidden
	bullet = viz.add('ball.wrl')
	bullet.scale(.1,.1,.1)
	bullet.visible(viz.OFF)
	#add a shadow, To be removed once final program is completed
	bullet.shadow = viz.add('shadow.wrl')
	bullet.shadow.alpha(0.7)
	bullet.shadow.visible(viz.OFF)
	#Enable collisions with the ball based on a sphere shape
	bullet.collidesphere(0.25)
	bullet.isTarget = 0
	collidables.append(bullet)
	#keep track of the last object the ball hit
	bullet.lastHit = 0
	#add the ball to the ball list
	bullets.append(bullet)
	bullet.active = 0
def shootBullet():
	global nextBullet
	#find the next available ball to shoot
	bullet = bullets[nextBullet]
	nextBullet = (nextBullet + 1) % NUM_BULLETS
	#Calculate the vector of the ball based on the mouse position
	bulletvector = viz.screentoworld(viz.mousepos())
	bullet.vector = viz.Vector(bulletvector[3]-bulletvector[0],bulletvector[4]-bulletvector[1],bulletvector[5]-bulletvector[2])
	bullet.vector.normalize()
	bullet.vector *= BULLET_SPEED
	#translate the bullet to the head position
	bullet.translate(viz.get(viz.HEAD_POS))
	#make the bullet and it's shadow visible
	bullet.visible(viz.ON)
	bullet.shadow.visible(viz.ON)
	#mark the bullet as active
	bullet.active = 1
def MoveBullet(bullet,elapsed):
	hitObject = 0
	#check if bullet is colliding with an object
	for object in collidables:
		#perform the collision check with the object
		info = bullet.collidingwith(object,1)
		if info.intersected:
			#set the bullets new vector to the reflection vector
			bullet.vector = viz.Vector(vizmat.ReflectionVector(bullet.vector,info.normalVector))
			#create a vector of the normal of the collision
			normal = viz.Vector(info.normalVector)
			#Check dot product of velocity and normal
			if bullet.vector * normal <0:
				bullet.vector*= -1
			#calculate the rotation vector of the ball
			bullet.rotvector = bullet.vector * rotRight
			#if object.isTarget and ball.lastHit != object:
			hitObject = object
			#play ball bounce sound
			viz.playsound('bounce.wav')
			break
	#get the bullet's current position
	pos = bullet.get(viz.POSITION)
	#calculate the balls future position based on it's velocity
	futurePos = pos + (bullet.vector * elapsed)
	bullet.translate(futurePos.get())
	#rotate the bullet along it's rotation vector
	#bullet.rotate(bullet.rotvector[0],bullet.rotvector[1],ball.rotvector[2],90*elapsed,viz.RELATIVE_WORLD)
	#Update the bullet's shadow
	bullet.shadow.translate(futurePos.x,0,futurePos.z)
def mytimer(num):
	if num == ANIMATION:
		#Calculate elapsed time since last update
		elapsed = viz.elapsed()
		#Update each active ball
		for bullet in bullets:
			if bullet.active:
				#Move the ball and check if it has collided with any objects
		#Update the crosshair position
		crosshair.translate(viz.mousepos()+[0])
#	elif num == START_DUCK:
#		global nextDuck
#		#Get the next available duck and start it
#		duck = ducks[nextDuck]
#		beginDuck(duck)
#		nextDuck = (nextDuck + 1) % NUM_DUCKS
#		viz.starttimer(START_DUCK,TIME_BETWEEN_DUCKS)
#Shoot a ball whenever left mousebutton is clicked
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,shootBullet)
#Create callbacks for timer events
##Start a timer which starts the next available duck
#viz.starttimer(START_DUCK,0.01)
#Start the animation timer, which animates the ball and checks for collisions
viz.starttimer(ANIMATION,0.01,-1)
#Move the head position back
viz.translate(viz.HEAD_POS,0,0,-10)
#Disable mouse navigation
viz.mouse(viz.OFF)
Old 03-02-2006, 06:03 PM
I've attached a modified version of the script which I hope will point out why you are experiencing this problem. First of all, I removed the crosshair because you shouldn't be using objects attached to the screen when using stereo. Second, I set the ipd value to 0. The ipd is the eye distance value. So both eyes will be at the same location. Third, I multiplied the x value of the mouse position by 2.0 when using the screentoworld command. This should cause the the bullet to come directly from the mouse position, for the left half of the screen. If you set the IPD value back to normal, you will experience your problem again. This is because in stereo mode the eyes are offset from the actual viewpoint position. I've attached an image which shows why the bullet appears to go to the left (excuse my crappy drawing skills ). Do you plan on the user using the mouse to aim while wearing the HMD?
import vizmat
import math
viz.go(viz.STEREO)
#arrays
#constants
#Set eye distance to 0 to show why the bullet goes to the left of the mouse
viz.ipd(0)
#Create six avatars
	global court
startAvatar(court)
	bullet.isTarget = 0
	bullet.lastHit = 0
	bullet.active = 0
def shootBullet():
	global nextBullet
	pos = viz.mousepos()
	bulletvector = viz.screentoworld(pos[0]*2.0,pos[1]) #Need to account for stereo
	bullet.active = 1
	hitObject = 0
				bullet.vector*= -1
			hitObject = object
			break
def mytimer(num):
			if bullet.active:
viz.mouse(viz.OFF)
Old 03-06-2006, 02:35 PM
For now we plan to use the mouse, however, when I tried this code, it didn't work for me. When I "shot" the avatars, nothing happened to them. So, now, after looking at this code, are you still sure that there is no way to adjust for the accuracy of the bullet when shooting to the sides? Thanks,
Old 03-08-2006, 11:06 AM
The code I posted was made with the latest internal version of Vizard. I realized that it won't work with the version you have. You just need to change the screentoworld command to the following:
bulletvector = viz.screentoworld(pos[0]+0.25,pos[1])
Also, I made this script to show the bullet coming from the mouse. I didn't add any picking to it, so nothing will happen to the avatars when you click them. As I already mentioned, this will only work when you set IPD to 0. However, having an IPD of 0 will make your HMD useless since you won't be receiving stereo images.
Old 03-08-2006, 01:41 PM
What do you mean by useless? I tried using the code w/the HMD and the bullet came exactly from the mouse position. Is there a way to make them perform an action when they are hit by a bullet? I wouldn't mind keeping the IPD at zero as long as the avatars would fall when they got hit.
Old 03-08-2006, 02:32 PM
The whole point of wearing an HMD is that each eye gets a different view of the scene. This is what make the image look 3D. Setting IPD to zero will effectively disable stereo since both eyes will be receiving the same view of the scene.
Here is some sample code that will play the hit animation when the avatar is hit by a bullet. Replace the code with whatever action you need:
import vizmat
import math
viz.go(viz.STEREO)
#arrays
#constants
viz.ipd(0)
#Create six avatars
	global court
startAvatar(court)
	bullet.disable(viz.COLLISION)
	bullet.active = 0
def shootBullet():
	global nextBullet
	bulletvector = viz.screentoworld(pos[0]+0.25,pos[1]) #Need to account for stereo
	#make the bullet visible
	bullet.active = 1
	#Check if bullet intersected with anything
	info = viz.intersect(pos,futurePos)
		if info.object in avatars:
			info.object.add(vizact.animation(7))
		bullet.visible(0)
		bullet.active = 0
	#Update balls positions
def mytimer(num):
			if bullet.active:
viz.mouse(viz.OFF)
