Thread Tools Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
Old 12-02-2025, 03:44 PM
josie_icoglab josie_icoglab is offline
Registered User
Question Grouping Objects from SightLab in Vizard
I am creating a 3d flanker task using sightlab and vizard. I added the environment and objects (flanker and target arrows) in sightlab, and am now finetuning the trials and manipulating the positioning of arrows in vizard.
I want to link the 4 flanker arrows as a group so they move as one from trial to trial, as they will always be manipulated in the same way at the same time per trial. I am a beginner with python and don't have much experience coding. I tried to use the sightlab AI to create code to do this, but was unsuccessful. This is the code that sightlab VR assistant gave me:
#position flankers and target at same depth and height:
import vizfx
#group flankers so they move and rotate as one, keep target separate:
flankerNames = ['L1_group', 'L2_group', 'R1_group', 'R2_group']
targetName = 'C_group'
flankerArrows = [vizfx.addChild(name) for name in flankerNames]
targetArrow = [vizfx.addChild(targetName)]
flankerGroup = vizfx.addGroup()
for arrow in flankerArrows:
arrow.setParent(flankerGroup)
#arrange flankers and a target in a line
spacing = 0.4
positions = {
'L2': -2*spacing,
'L1': -spacing,
'R1': spacing,
'R2': 2*spacing,
arrow.setPosition(positions[arrow.getName()], 0, 0, mode=viz.REL_LOCAL)
#position of flankers relative to participant
depthZ = 2.0
heightY = 1.5
centerX = 0
flankerGroup.setPosition(centerX, heightY, depthZ)
targetArrow.setPosition(centerX, heightY, depthZ)
#face participant
flankerGroup.setEuler(0,0,0)
targetArrow.setEuler(0,0,0)
The error code I am getting is: AttributeError: module 'vizfx' has no attribute 'addGroup'.
Just wondering if anyone has any idea how I could group objects as one, or how to adjust this code so that it runs?
Old 10-07-2026, 09:38 AM
There's a few ways to approach this:
You could still use the GUI, but then would need to create copies of your environment with the stimuli rotated or moved and then add that modified environment to each trial. An example that uses this method is the Visual Search Single Object GUI SightLab Projects\ExampleScripts\VisualSearch\VisualSearch1 _SingleObject_GUI
https://help.worldviz.com/sightlab/v...e-manipulation
Also, using mostly the GUI you can just access the arrow objects if they are added in Inspector by using env,.getChild('nameOfObject'), so like this:
def sightLabExperiment():
yield viztask.waitEvent(EXPERIMENT_START)
viz.callback(viz.getEventID('ResetPosition'), sightlab.resetViewPoint)
env = sightlab.getEnvironment()
arrow1 = env.getChild('nameofArrow')
arrow1.setPosition([0,1,0])
arrow1.setEuler([180,0,0])
You could definitely use a STIM file, you would then also need either just the objects rotated or moved differently or the full environment and modify which one to present via the STIM file
https://help.worldviz.com/sightlab/stim-files/
You could fully create this with code. For help with coding I would recommend first trying with the SightLab GPT Assistant (can change this to GPT 5.2 for more thinking/better responses). You just need an OpenAI account (a free one works as well) and can access that here:
https://chatgpt.com/g/g-tgG8cOR5i-sightlab-vr-assistant
For example here is what I got from the Assistant. You just need to press trigger to start, then A or D for right or left and then trigger to start the next trial
import random
import math
import vizfx
import vizshape
import viztask
# 1) Initialize SightLab
# NOTE: vizshape objects need headlight=True so they render nicely.
sightlab = sl.SightLab(gui=False, headlight=True)
sightlab.setStartText('press Trigger to Start')
# If you're not using the GUI, you must set an environment in code:
env = vizfx.addChild('sightlab_resources/environments/whiteroom.osgb')
sightlab.setEnvironment(env)
# 2) Helper: build a simple 3D "arrow" out of vizshape primitives
def makeArrow(scale=0.12):
Creates a right-pointing arrow (points +X by default).
Returns a viz.Group node you can position/rotate as one object.
g = viz.addGroup()
# Shaft
shaft = vizshape.addBox(size=(0.35, 0.08, 0.08))
shaft.setParent(g)
shaft.setPosition(0.0, 0.0, 0.0)
# Head (cone)
head = vizshape.addCone(height=0.18, radius=0.09, slices=20)
head.setParent(g)
head.setPosition(0.22, 0.0, 0.0)
# Cone points +Z by default in many cases; rotate so it points +X
head.setEuler(0, 0, -90)
# Scale the whole arrow
g.setScale(scale, scale, scale)
# Optional: give a neutral color
g.color(viz.WHITE)
return g
def setArrowDirection(arrowNode, direction):
direction: 'L' or 'R'
Arrow is modeled pointing +X (Right). Left is 180° about Y.
if direction.upper() == 'R':
arrowNode.setEuler(0, 0, 0)
arrowNode.setEuler(180, 0, 0)
# 3) Create flanker layout: 4 flankers + 1 target (center)
# Positions are in meters (SightLab uses meters)
Y_HEIGHT = 1.5 # roughly eye level in many setups
BASE_Z_NEAR = 1.0 # near depth
BASE_Z_FAR = 2.0 # far depth
# Horizontal spacing of arrows (meters)
X_SPACING = 0.18
# Make nodes
flanker1 = makeArrow()
flanker2 = makeArrow()
target = makeArrow()
flanker3 = makeArrow()
flanker4 = makeArrow()
# Parent them to the environment so their positions are in environment space
for n in [flanker1, flanker2, target, flanker3, flanker4]:
n.setParent(env)
# Base positions (Z will be set per trial)
flanker1.setPosition(-2*X_SPACING, Y_HEIGHT, BASE_Z_NEAR)
flanker2.setPosition(-1*X_SPACING, Y_HEIGHT, BASE_Z_NEAR)
target.setPosition(0*X_SPACING, Y_HEIGHT, BASE_Z_NEAR)
flanker3.setPosition(1*X_SPACING, Y_HEIGHT, BASE_Z_NEAR)
flanker4.setPosition(2*X_SPACING, Y_HEIGHT, BASE_Z_NEAR)
# IMPORTANT: Add objects to SightLab for data collection.
# If you want gaze data on them, set gaze=True.
sightlab.addSceneObject('flanker1', flanker1, gaze=True)
sightlab.addSceneObject('flanker2', flanker2, gaze=True)
sightlab.addSceneObject('target', target, gaze=True)
sightlab.addSceneObject('flanker3', flanker3, gaze=True)
sightlab.addSceneObject('flanker4', flanker4, gaze=True)
# 4) Define "STIM-like" trial table in code
# (In a real project, you’d often read this from a CSV/STIM file.)
TRIALS = []
n_trials = 20
for i in range(n_trials):
congruency = random.choice(['congruent', 'incongruent'])
depth = random.choice(['near', 'far'])
target_dir = random.choice(['L', 'R'])
if congruency == 'congruent':
flanker_dir = target_dir
flanker_dir = 'L' if target_dir == 'R' else 'R'
z = BASE_Z_NEAR if depth == 'near' else BASE_Z_FAR
TRIALS.append({
'congruency': congruency,
'depth': depth,
'target_dir': target_dir,
'flanker_dir': flanker_dir,
'z': z
sightlab.setTrialCount(len(TRIALS))
# 5) Optional: simple response collection + RT (keyboard)
RESPONSE_LEFT_KEY = 'a'
RESPONSE_RIGHT_KEY = 'd'
def applyTrialConfig(cfg):
# Set directions
setArrowDirection(target, cfg['target_dir'])
for f in [flanker1, flanker2, flanker3, flanker4]:
setArrowDirection(f, cfg['flanker_dir'])
# Set depth (same z for all arrows in this simple example)
z = cfg['z']
flanker1.setPosition(-2*X_SPACING, Y_HEIGHT, z)
flanker2.setPosition(-1*X_SPACING, Y_HEIGHT, z)
target.setPosition(0*X_SPACING, Y_HEIGHT, z)
flanker3.setPosition(1*X_SPACING, Y_HEIGHT, z)
flanker4.setPosition(2*X_SPACING, Y_HEIGHT, z)
# 6) Main trial loop
for t in range(sightlab.getTrialCount()):
cfg = TRIALS[t]
# Show trial-start text (SightLab will use trigger/left-click by default to continue)
msg = (
f"Flanker Task\n\n"
f"Respond to the CENTER arrow only.\n"
f"Press '{RESPONSE_LEFT_KEY.upper()}' for LEFT, '{RESPONSE_RIGHT_KEY.upper()}' for RIGHT.\n\n"
f"(Trial {t+1}/{len(TRIALS)} | {cfg['congruency']} | {cfg['depth']})\n\n"
f"Press Trigger to Start"
yield sightlab.startTrial(startTrialText=msg)
# Start RT timer at trial start
start_time = sightlab.hud.getCurrentTime()
# Wait for response
key = yield viztask.waitKeyDown([RESPONSE_LEFT_KEY, RESPONSE_RIGHT_KEY])
rt = sightlab.hud.getCurrentTime() - start_time
resp_dir = 'L' if key == RESPONSE_LEFT_KEY else 'R'
correct = (resp_dir == cfg['target_dir'])
# Log to console; SightLab will also log trial timing automatically.
print(f"Trial {t+1}: target={cfg['target_dir']} flankers={cfg['flanker_dir']} "
f"cong={cfg['congruency']} depth={cfg['depth']} resp={resp_dir} "
f"correct={correct} rt={rt:.3f}s")
yield sightlab.endTrial(endTrialText="")
# 7) Schedule SightLab
viztask.schedule(sightlab.runExperiment) # required for data collection loop
viztask.schedule(sightLabExperiment) # your experiment logic
viz.callback(viz.getEventID('ResetPosition'), sightlab.resetViewPoint) # 'r' to reset
grouping, objects, sightlab, vizard
Motion Builder + Vizard Objects ForeverBound Vizard 1 04-01-2015 04:49 AM
Grouping Objects javadi Vizard 3 09-17-2013 08:14 AM
Picking up Vizard Objects on mouse down with collisions pwsnow Vizard 2 09-17-2012 03:02 AM
