Old 02-19-2020, 09:54 AM
josephredfern josephredfern is offline
Rotating objects about a point
I have have a list of nodes (returned from viz.addChild). I wish to rotate all of these models about the Y axis of a single point (specifically, 180 degrees). What is the best way to do this? I've tried using setCenter (setting the new center to the position about which I wish to rotate each model) in combination setEuler without success...
Thank you,
Joe
Rotating an object around a point BWhiteDerby Vizard 1 08-25-2015 05:37 PM
joints/spin objects rmcconnell11 Vizard 0 02-17-2014 08:13 AM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 01:04 PM
