Old 08-18-2018, 09:28 AM
To toggle the flash effect add a boolean variable that can be toggled (e.g with keypress). Then only run the flash effect code if the boolean value is true.
animation, optotrak, pit, vizact
Road Animation Path vserchi Vizard 4 11-12-2015 10:29 AM
Unusual tracker sensor setup with Vizard Zhi Vizard 2 06-12-2012 10:52 AM
Integrated orientation tracker in zSight HMD Zhi Vizard 2 06-06-2012 09:29 AM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 01:03 AM
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 05:23 PM
